Lenovo ThinkPad Z60t (2511-ECU) 14in. Widescreen Notebook Computer With Intel Celeron M Processor 370 (S4531587) PC Notebook Logo
Anonymous Posted on Dec 07, 2012
1993 toyota hilux surf ssr-x3.0 overdrive not working
max carson
Level 3:
  • Lenovo Master 7,627 Answers
  • Posted on Dec 08, 2012
max carson
Lenovo Master
Level 3:
Answers
7627
Questions
Helped
1013653
Points
21773
Toyota repair manual 1992 hilux surf ssr-x
Hi. it could either be engine lacking power ie fuel or fuel pump,
rings,compression down,brakes binding,timing no vacuum advance working, or clutch slipping.
Toyota hilux surf ssr x 1994 3.0 litre turbo diesel 1kz te
Check this video and leave him a message about your user manual,may help you get one.
1993 toyota hilux surf over drive just stoped working
You didn't happen to push the little button on the side of your gearshift? If not, check your fuses.
1helpful
1993 toyota hilux surf ssr-x 3.0 overdrive not working
The following are the general instructions on the start of diagnosing any electronically controlled engine or transmission problem.
The engine and the automatic transmission (transmission control is only for automatics, engine is still computer controlled no matter the transmission type) in this vehicle are computer controlled and in most cases when a fault occurs a fault code is stored in the memory of the computer control module. There are exception to this, such as the Mass Airflow Meter and fuel pressure problems. What must be done is to have all the basic testing done such as a scan of the system for fault codes as well as a check with a live data scanner tool for engine functions that are not within range of normal, a trained technician is required to know what is correct and what isn't, then based on careful diagnostics done from a factory repair manual the correct part is replaced or the wiring repaired or the computer replaced (known as the PCM or ECM,ECU), which is very rarely the problem. Other basic checks must be done as well such as mechanical problems with the engine as well as engine state of tune and mileage on the engine. The transmission can have mechanical issues as well such as no gear engagement at all or a failed pump or other pressure related problems. Also engine mechanical problems can and do cause many drive-ability related problem such as rough idle and other symptoms.
1helpful
Toyota hillux vigo
Click the help link below,in related to toyota Hilux.
Toyota Hilux Surf Fuse Box Diagram? http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
How to lower fuel pressure on Toyota Hilux? http://schematicsdiagram.blogspot.in/2012/02/how-to-lower-fuel-pressure-on-toyota.html
2012 Toyota Hilux SR5: Immobilizer override and bypass? http://whatisbyme.blogspot.in/2012/05/2012-toyota-hilux-sr5-immobilizer.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
These details should help.
for more help.
keep updated with more details.
Thanks.
Where is cig lighter fuse on toyota hilux surf ssr-x
Cig lighter fuse located in fuse box under driver side foot-well.Click the link below for fuse box diagram:-----http://technoanswers.blogspot.in/2012/06/toyota-hilux-surf-fuse-box-diagram.html
--------This will help.Thanks.
Electric windows
If you post your email i can email you the wiring diagram
4wd
you want to be in 4w drive H...........high...................the L or low is for off roading
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
