Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Excessive noise There is excessive noises when washing/rinsing the dishes. Do I need to take the wash unit apart? Does anyone know how? Thanks
  • stuart shanken Jun 11, 2007
    You mention removing the sides. My built in dishwasher doesn'tt have sides. Do you mean accessing from below? How do I check the filter?
    Thanks
    Sergeant:
  • 236 Answers
There may be a obstruction in the wash pump or the wash pump is damaged or on the way out. the wash pump is located in the base and is accessable from removing the sides. it will be a big job being an integrated unit. check also under the filters to see any debris.
Posted on Jun 11, 2007
  • tony howlett Jun 12, 2007
    yep sorry thats what i meant, the filters will be the ones inside the bottom of the unit, under there is the entrance to the wash pump where you may have had an item squeeze through.
    the wash pump will be a fairly sizeable unit underneath. tone.
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Hobart dish machine. We were told by Ecolab tech that we need to rinse off all presoak, soaps and sanitizers before passing through the maching as they cause foaming/excess suds. I do not find that info...
That's true. excess of foam can cause poor wash pressure and poor final rinse.
Operation manual , pag.24. (F17791Rv02-06.pdf)
DO NOT exceed chemical manufacturer's recommended concentrations for detergent, sanitizer, rinse aid or lime scale remover.
Mar 13, 2015 | Hobart Dishwashers
Fischer paykal dishwasher drawer leaving white powder on dishes
If rinse aid levels in dispensor are ok then check if it is being used. the rinse aid setting may be set too low.
Dec 24, 2012 | Fisher and Paykel DD605SS Stainless Steel...
Check filter light is on...I wanted to know can the filter be washed or does it have to be replaced
purplebunny, without know which brand and model number your AC unit is, it's hard to tell you. However, if it's a foam or plastic mesh filter, in a plastic frame, it is washable with warm water and dish washing liquid. Rinse it thoroughly and do not reinstall it until it's completely dry. Any other type filter will need to be replaced.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | Heating & Cooling
There is a white residue remaining on dishes after every washing/drying. If I add 1/4 cup lime-a-way, it helps. I have changed detergents, from Cascade to Finish, no difference. And, I have actually...
Hi and welcome to FixYa, I am Kelly.
First question is the unit under warranty? If it is DO NOT do anything other than the wash arm inspection that you already did on the inside of the unit. You will void the warranty.
Now outside the unit here is what you should do. Check the drain ports from the sink / garbage disposal connection all the ay back to where it connects to the bottom of the dishwasher for obstructions. The garbage disposal port is the source of many dishwasher drain / dirty post cycle dishes problems. This MUST also include taking the Air-Gap apart but lifting off the cover... unscrewing the inner cap nut and inspecting for food particles. The Air-Gaps are notorious for catching food particles just under the upper U cap that reverses the water flow direction. As you take the Air-Gap nut off and lift the inner cap.. NOTE the installed position. It only fits in ONE WAY and can give you fits! Just make sure you align the inner U cap in the original position.
Residual water in the bottom of the dishwasher post cycle is a sure sign of a drain problem.
One other thing you can also use to rid yourself of spotted post cycle dishes is a product called "Jet Dry" Rinse Agent. (assuming there are no drain problems) It comes in bottles for units with internal rinse dispensers and hanging baskets for those units without rinse dispensers.
If you unit is not under warranty there is more that can be done. I do however think that if you perform the above checks that you will resolve the issue.
Thanks for choosing FixYa,
Kelly
Jan 30, 2011 | Maytag Dishwashers
Just bought home with Kenmore dishwasher. Know
Do you have the operating instructions for your dishwasher. If not, open the door and there should be a manufacturer's badge on the inside of the door somewhere. Find out what model machine you have. I can help you find a manual online.
A couple of general tips for your info.
  • Wipe or rinse excess food particles from dishes before you stack them in machine.
  • Stack neatly and spaced apart to give better wash results.
  • Make sure dishes and pot handles are clear of the sprinklers. Turn sprinklers by hand and make sure they dont hit against anything.
  • I prefer using dishwashing tablets as they are a measured amount. Best not to use too much soap or powder.
  • If you are using powder, use rinse aid along with it.
  • Dont put your crystals or good wine glasses in the dishwasher.
Hope this helps somewhat.
good luck.
Ash
Oct 23, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
When the wash cycle is done, the dishes are wet
It seems that the newer dishwashers are worse at drying dishes than their tupperware melting predecessors were. They have all been tuned down, and do dry less. The only thing that you can do is to set your machine for the hottest wash, power dry and use a rinse agent that provides a sheeting action. Some folks use white vinegar as a supplement to their rinse aid, which has the added bonus of killing mold. Water also stays attached if the water has laid down minerals as noted by cloudy glassware. If this is the case, a dishwasher filter (dishwasherfilter.com, $70) might help. We try to wash hot, with a power dry and use a rinse aid/vinegar. Then, when the cycle is complete, but the dishes are still hot, we open the dishwasher, and "jiggle" the racks to get the excess water off of the glasses, and leave the dishwasher open about 2" at the top, so the dishes will continue to air dry. This has been an effective method for us.
Best regards, --W/D--
Aug 03, 2009 | Siemens Dishwashers
Doesnt dry dishes
The heater on this unit only comes on twice, once in the wash cycle, and again in the Sanitary rinse. During the drying cycle all that happens is a vent opens and a fan comes on. The fan removes the hot moist air from the unit and the dishes dry off. If your water is not hot enough, this is why your dishes are still wet. Rinse aid also helps to sheen off the excess water as well.
Sgt 48
May 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Whirlpool gold builtin dishwasher
Do not recommend premeasured tablets, usually too much soap. If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and make the soil sensor think the dishes are real dirty initiating additional wash cycles. Use rinse-aid for better drying performance
Apr 28, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Indesit D63 dishwasher dishes not getting clean
Dishwasher seems to cycle through but dishes are still dirty, like there is no water being sprayed?
Jan 23, 2008 | Dishwashers
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
123 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
