Question about Kenmore Refrigerators
Model 978-339 serial no.
I need to know how old is this fridge two doors going vertically freezer left top to bottom fridge on right side top to bottom
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 08, 2012
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
SOURCE: Frigidaire Side-By-Side Top Not Cooling
sounds like its froze up. the coil is in the back of the freezer and blows into the freezer via a fan then cold air is carried to the fridge via another fan. more than likely condensation due to weather conditions has built up on your coil and has froze up or your fridge fan has stopped working. unplug fridge for a day to let thaw, if this doesnt work check you air distribution fan in top.
as for the lights not working in the freezer the switch is on the left hand side of freezer wall under ice holding tank sometimes water from thawing ice get on it and it wont come out all the way, take a blow dryer to it to thaw and dry it out.
Posted on Feb 17, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
SOURCE: top of fridge warm but bottom freezer working ok
there is also a fan in the freezer compartment which if broken will cause this problem. you need to check that both fans are working. please refer to other fridge posts here re repairing/ replacing the freezer fan- there is a document here which shows you exactly what you need to do. important thing is to switch off the appliance first and leave the freezer door open for about 20 minutes before attempting to remove the back cover ie let it warm up first, so that you don't break any of the panels.
Posted on Jan 05, 2009
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
Why are my fresh vegetables freezing in my vegetable bend and my sour cream freezing on my top shelf in refrigerator. Got to be something simple. Thanks
send the model number off of the machine,if freezer is on bottom or side by side open the fridge door,look up on the right hand wall up near the ceiling and you should see a tag with the model and serial numbers,if freezer is on top open the fridge door and look at the left side wall up near the ceiling
Jan 01, 2018 | Refrigerators
Maytag side by side door slamming shut
what's the model number and what's happening with it,do you mean the fridge is on top and freezer on bottom?open the fridge door,look up on right hand side up near ceiling and send the model number and the first two numbers of the serial number
Jun 18, 2012 | Maytag Refrigerators
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Freezer fan is noisey and can t find serial number
The number you will need is the model number. On side by side models there are a few places to look. 1- inside fridge on right or left wall. 2- Open fridge door and look up near the top front lip. 3- Open both doors and look on body of fridge under the doors. 4- Fridge door sometimes there is a sticker right when you open. Mostly you are looking for a silver sticker or silver plate. It gives you a model number and serial number. If you need further assistance please mail me back.
May 26, 2011 | Kenmore Side by Side Refrigerator
Have broken two bottom shelves in fridge door. Model no SRL551DP
Whats the serial number of the fridge. Its inside the fridge on the left on top of the sticker and also outside the left side of the freezer
Nov 08, 2010 | Samsung Refrigerators
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Mar 30, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
81 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
