Question about Maytag EPICz Electric Dryer
Maytag Epic Z Washer F-20, Water Inlet replaced, still F-20 Error
I have replaced the water inlet unit inside the machine where the 2 hoses connect. That didn't solve issue. If I have hoses on correctly, hot hose on hot inlet and cold hose on cold inlet and choose cold wash, I get F20 after a few minutes of cycle starting. But If I switch the inlets and put hot hose on cold inlet and cold hose on hot inlet, then run a HOT cycle, it washes clothes in cold water all the way through the cycle with no issues at all. Any ideas?
  • 2 more comments
  • Chris Dec 07, 2012
    I chose Dryer on accident. This is a washer, not a dryer.
  • Chris Dec 09, 2012
    This is a Maytag EpicZ Washer, not a Whirlpool. I didn't see a tech sheet in my machine, but all I did was take the top off and replace inlet valve. Also I didn't see a manual for the Maytag Epic Z washer via your link.
    After posting the other day, I did find a service manual on the Internet and have it. I guess I just have to go through and check all the parts diagnostically as it says in the manual. I will for sure check the filter thing first if that also applies to the Maytag.
  • Maytag Master
  • 8,220 Answers
Chris an F-20 is usually a clogged filter on duet washers. Did you go by the tech sheet in your machine? It gives the codes and remedys and is in a jacket behind the kickplate which you remove to get to the filter. You will need a quarter inch nutdriver to gain access.
SERVICE MANUAL is HERE on my manual page
Posted on Dec 07, 2012
Testimonial: "Great work by Dan pointing out issues that aren't in the manual and only known by experience in the field. Thanks again Dan for the help."
  • 9 more comments
  • Chris Dec 10, 2012
    So I took the kickplate off late last night and seen the service notes, not much help other than it points to the Pressure switch being bad just as I seen in a forum post last week. I did see the drain pump as shown in the video, but I didn't have time to take it apart, try to do that tonight. ARe you saying the filter you refer to in your post is the same thing the guy is cleaning in the video?
  • Dan Webster
    Dan Webster Dec 11, 2012
    The f-35 error in the duet shows replacement of the analog pressure switch. The F-21 in the duet show more on the filter clogged.
  • Chris Dec 11, 2012
    But this is F-20 error only, not F-35, not F-21
  • Dan Webster
    I have an epic z manual somewhere lets see: page 80 says among other thangs verify pump draining. Since you already donr the water valve thang..https://docs.google.com/file/d/0B5If-wTg...
  • Dan Webster
    Thanks Dan, that is the exact manual that I said I found last week. So I actually lietarlly just sat back down from working on it. So I went through and check all the components with an ohm meter, most everything was 100% solid, few things questionable, so anywho, After putting all back together, I get F-30 now, and F-20...lol. So I found out why the F-30, fixed that, ran a cycle with no clothes on cold/cold with hoses still swapped cold on hot and hot on cold, worked with no problems. I haven't been able to run that cycle for months. Going to bed or would do more testing including hooking hoses up correctly and running a real cycle. Only thing that bothers me is that when I run diagnostics by holing button 4 seconds/release 4 seconds, I still get F-30 and F-20.
    one more thing to add, I did unscrew that drain as the first video shows and blueish/greyish water came out. It also smelled insaely disgustingly terrible. Is that common or does that indicate an issue?
  • Dan Webster
    Dan Webster Dec 12, 2012
    Get some tide washing machine cleanser. Go by package directions. Their are 3 treatments use as many as it takes.
  • Chris Dec 12, 2012
    Hey Dan, Thanks for the reply. I know the washer has needed to be cleaned for a long time and it wouldn't allow me to because of F20. So today when I got home from work, I moved hoses back, cold on cold, hot on hot. And then put in 2/3 cup bleach as manual says, then ran the clean washer cycle. It went with no issues at all. So I ran a rinse and spin only cycle to test, after 8 mins or so, no error so cancelled, then ran a full normal cycle on cold/cold, and it is going now with no issues. 44Mins left and going along with no issues. It would have already F20''d by now normally, so I think the issue is fixed. I think my main problem was the little metal connectors on the wire connecters that weren't touching the board good so it wasn't making connection and throwing errrors, I used tip of my pocket knife on a few of them to push them back toward the center so they would grip the board easier, that or the draining the bottom of the unit fixed the issue, not sure which, but I know the metal connectors were the problem when the F30 came up after all my component testing.
    Again, thanks a ton Dan for your help
  • Dan Webster
    Glad ye could git er done!
5 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: maytag neptune mah4000aww 53314036yk
Check the solenoid. It may be bad. This allows the water to come in.
Posted on Jan 14, 2009
tshot2020
  • 16 Answers
SOURCE: NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Posted on Apr 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: Maytag Performa dryer runs but the timer doesn't
The heating element have got old and brittleover time and finally gave up the ghost. But it is not always theelement. It could be one of the safety Hi-limits have blown. All partsof the dryer will have continuity if its working properly. Test forcontinuity by using a meter set on Ohms,or use a poor man's meter. Youcan make your own poor man's meter by using an ordinary flashlight .Break the circuit in the flashlight and add a couple of wires to it sothat you can make the light come on in the flashlight, that's right hotwire that flashlight. When the bulb lights up you have a circuit! Younow have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the sideof the heat element, the door switch (when door is closed) etc.shouldhave continuity (closed circuit)(the light should come on in the poorman's meter) If you come across an thing near the blower housing with 2wires attached to it, that is a thermal limit, a safety or a controlthermostat (So as not to get a false circuit you need to remove one ofthe wires to each thing you check) Look for lint buildup or blockedvent going out the house. If everything is good and you have paid theelectric bill, then the timer could be bad.
Posted on Dec 13, 2009
localwonder
  • 6784 Answers
SOURCE: Washer won't start running water in so is locked
HI, This may be the result of a failed inlet assembly. Use my procedure below to inspect for damage.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
If the inlet passes the test, and inspection, this will confirm that the problem is within the main control sector.
Posted on Dec 22, 2009
Kenmore eco cycle front load washer. error E70 displays and stops washer. What does E70 mean?
You should check the model number of the washer. If the model number starts 417, then the washer was made by Frigidaire. In that case, the E70 error indicates that cold water is not being detected at the washer inlet sensor.
In some cases, this could be due to connecting the hot water line to the cold water inlet (and the cold water to the hot water inlet). Make sure that the cold water shut-off valve is open. Try swapping the water hoses (close the shut-off valves first). Try new hoses; some anti-flood hoses will restrict the water flow if they detect damage. Thus you won't have sufficient water coming into the washer. (You can check this yourself. Turn off the shut-off valves. Disconnect the hoses from the washer and put the ends into a bucket. Then open the shut-off valves and check the water flow.) While you have the hoses off, check for debris in the inlet filters.
If the hoses are fine, you probably have a problem with the washer's inlet valve or the reed switch that measures incoming water. The inlet valve should be replaced if you find that only hot water enters the washer.
I hope this helps. Please add a comment with the model number of your washer for more information. It will be on the inside of the door opening (probably at the top).
Sep 30, 2013 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic FH Error
follow this steps .God bless you
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
Jul 22, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I get an F H code. I bought a new inlet value which fixed the problem for about two weeks. I then installed the old one wich lasted another 2 weeks. How can I find and fix the correct problem. Maytag ...
As i suppose you know by replacing the water inlet valve that the F-H error code means now water was detected entering the washer. having replaced the water valve,one thing you should check,espically if using"aqua flow flood stop" braided steel inlet hoses from the house water supply,is if water is flowing through the inlet hoses into the washer, if your using that type of hose from the faucet they have a problem in them and the internal flood stop device inside the hose fails and even though the water faucets are on no water is getting into the washing machine. Also or even if using those type hoses disconnect them from washer and check for water flow through them when not connected to washer. If water flow is good into washer replace this part called the flow meter part # W10110225 it measures and tells the control that water is coming into the washer. It the flow meter can of course be purchased where you got the water inlet valve.
Good luck,
Gene
Aug 19, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washer flashing FH, first F, then H
"FH" (Water Inlet Problem-no water or insufficient water
supply)
Select PAUSE/OFF twice to cancel the cycle. Unplug washer
or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Also check the pressure hose for cracks or worn through spots, and pressure switch.
May 30, 2011 | Maytag EPIC MFW9700S Front Load Washer
When washer starts to wash it beeps and flashes the letters FH.
Hi
Error FH means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If the machine is not filling then check whether both valves at water source are turned ON and inlet hose are not plugged. If the machine is filling fine then chec the pressure switch hose and the drain hose for siphoning (also make sure water is not flowing back to the machine from drain hose). Check wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Hope this helps... Please post back if you need more information.
Daniel
Jan 17, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a Maytag front loader Mod. MFW9700SQ1 - I get an error code of H and then F flashing. The machine stops washing. What could be the problem?
Hi
Error HF means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If the machine is not filling then check whether both valves at water source are turned ON and inlet hose are not plugged. If the machine is filling fine then chec the pressure switch hose and the drain hose for siphoning (also make sure water is not flowing back to the machine from drain hose). Check wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Hope this helps... Please post back if you need more information.
Daniel
Jan 02, 2011 | Maytag EPIC MFW9700S Front Load Washer
My washer is beeping and flashing the letter F
It means no water detected entering machine or Pressure switch trip not detected.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
3. Verify inlet valve operation.
1. Verify Drain pump operation.
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch.
3. Verify there is not a siphon problem.
4. verify wire harness connections to Inlet Valves,Pressure Switch,Drain Pump,Flow Meter and
5. Check all hoses for possible leaks.
6. Verify pressure switch operation.
7. Verify flow meter operation.
Apr 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer will not run displays "FH" on the front
(((FH)))
Or
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component.
Jul 28, 2009 | Maytag EPIC MFW9600S
Error Code F-20
I have same machine and manual says, "F20" on display (water inlet problem - no water or insufficient water supply). Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following. Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re select cycle and press START. if the problem remains, call for service.
May 13, 2009 | Kenmore HE2 Plus Front Load Washer
Maytag Epic Z washing machine F20 error
F-20 error code its water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Jul 17, 2008 | Washing Machines
Maytag EPICz Electric Dryer Logo
656 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
