Question about Dacor Millennia ETT365 Electric Cooktop
Top right burner will not work
Dacor ETT365 Touchtop - Top right burner does not heat up. There is no response from the touch sensor when trying to to turn it on. The up and down sensors beep when touched but of course have no effect sicne there is no heat. My wife says that the other lights on the touch top have been turning on and off and flashing erratically from time to time but I have not seen this myself. Any suggestions on a fix? How can I lift the top to check for loose connections?
    Problem Solver:
  • 16 Answers
Your units connections are slowly becoming comprimised. Before our unit went out completely, it went through this phase. A cleaning should fix it.
1. After the unit has cooled down, with all of the 'reminder' lights off. Turn off the main power at the fuse box. You NEVER want to work with an electrical appliance's innards with power being supplied to it.
2. Remove the unit from the countertop. Turn it over and rotate it if needed so that the power supply is not tightly pulling it. Remove the two screws holding the clamp on the power supply wiring.
3. Remove the screws holding the two different boxes together, and the screws holding the main box to the unit. Lift up the two pieces separately, careful not to yank them apart.
4. Remove the ribbon connector from the green computer board. Open the teeth on both sides of the pin and remove it.
5. Using needle-nosed pliers, squeeze on the white plastic posts holding down the upper board. Lift the corners of the board up gently, working with one at a time. Gently remove the board.
6. Look for corrosion or contaminants. Spray the entire lower board clean with compressed air. Spray the entire upper computer board clean with compressed air. Gently replace the upper board onto the 4 white plastic posts.
7. Spray the end of the ribbon connector, then replace it into the upper board. Remove the other end from the main board and spray it before replacing it.
8. Gently touch all the connections, looking for any that have loose contacts. Do not pull on any wires. Spray the entire board, and the adjacent fan, with compressed air.
9. Reassemble the protective coverings and then the power supply clamp.
10. Return cooktop to normal position in counter.
11. Restore main power at the fuse box. The unit should send a series of lights through every bulb, TWICE. If this was the solution to your problem, it is now fixed. :-)
Posted on Jul 07, 2009
New dacor ett365 not turing on
See if any of these instructions will work:
http://www.uakc.com/Downloads/Instal/ETT3inst_3.pdf
Or try calling the customer service:
Dacor Customer Service Team
Phone: (800) 793-0093 (U.S.A. and Canada)
Monday - Friday 6:00 a.m. to 5:00 p.m. Pacific Time
Web site: www.Dacor.com
Jul 28, 2012 | Dacor Millennia ETT365 Electric Cooktop
One of the burner controls automatically lowers itself to the "1" setting. If I turn it up it goes right back to "1" by itself
Hello, and sorry to read about your problem.
Sounds like you have a general main board failure, or a touch pad sensor issue
I suggest you call a service company
I tried to help you. Please help me and vote/rate my response thanks.
Dec 15, 2010 | Dacor Millennia ETT304 Electric Cooktop
The "lock out" button will not release to allow burners to come on for use.
Try turning off circuit breaker for about 2-3 minutes.
This should reset the main PCB.
If not contact dacor customer service @
800-793-0093
Jan 09, 2010 | Dacor Millennia ETT365 Electric Cooktop
I have a 5 burner Dacor Cooktop (SGM365) with which I am having trouble with the right rear burner not sparking. There is gas flow and the other burners are lighting just fine. I've taken the burner apart...
In the middle of each burner, there is a small brass ring that screws in the burner. If you unscrew all five and pull the knobs, the top should come off. From there you can access the electronics. Because all the burners ignite at the same time, I would suspect either a disconnected or shorted wire on your right burner or some corrosion has occurred at that burner preventing it from grounding properly.
Nov 09, 2009 | Dacor Preference SGM365 Gas Cooktop
SGM464EM cook top valve rplacement
you have to go in from the top ,,, take off burner, knobs and the screws holding top and raise to get to valves / larry
Dec 11, 2008 | Dacor Preference SGM466 Gas Cooktop
Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
May 27, 2008 | Dacor Preference SGM304 Gas Cooktop
Oven Striker
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
Oct 12, 2006 | Dacor Preference SGM466SS Gas Cooktop
Dacor Millennia ETT365 Electric Cooktop Logo
288 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
