Question about Bissell 2080 QUICKSTEAMER Upright Vacuum
Bissell quicksteamer model 2090-8 leaks water
reddevil6
  • 1673 Answers
SOURCE: won't extract water from carpet.
Seems the 1950W is now obsolete, cna't even bring up a drawing of it. Usually when the vac. motor is running, then there has to be suction. But if a seal or gaske is missing, then the suction will be lost. So you might check the dirty water tank to make sure there isn't a part missing or out of place. Check this out, it is for a 1950-3:
http://bissell.com/images/schematics/1950.pdf
Posted on Jan 31, 2008
SOURCE: Bissell 1770 Quicksteamer ii
Looking for ther dang Instructuion booklet which/which I just saw in last day or so/ and it says what model it is.,,
altho its says quciksteamer right under the Bissel product name on the front up by handle and electrical wire holder--the SOLUTION tube runs down around the mortor housing but NO type of heating unit--So I don't get why the call it QUICKSteamer..is another GUESS
with no water is heated except for when I do use hot water or have boild water--not putting the boilng water in to tank tho=the solution flows FINE--and sems to be flowing from all sprouts
I'm not stupid-
I workled for yrs In MY dads aplpliance Co--we reapired Maytag washer & Dryers which seldom needed fixed...my lint brush I will chech & CLEAN AGAIN-- AND Pretty sure ALL FITTINGS ARE seating PROPERLY--just can get it to SUCK--the dirty water back into holder tank-unsit hasnt been used more than a dozen times..amd has worked preffect all those other times..
Seems when all esle SUCKS the vacum cleaner or Rug Shampooer WON'T
Posted on Mar 04, 2008
whytfang
  • 170 Answers
SOURCE: bissell manual
Sorry this is as close as I could come...but *** covers the Quicksteamer 1970 model...and surely it is the exact same process for yours...as this manual covers several models.....I found it at www.bissell.com.....I hope this helps...good luck and thanks For rating my effort....The Fang
http://www.bissell.com/images/UserGuides/1770_0206.pdf
Posted on May 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: I need to know how to use Bissell Quicksteamer
CLICK HERE for your manual in PDF format.
THanks for using Fixya - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 22, 2009
SOURCE: How do I fix Bissell Quicksteamer leaking from
I have the same problem... seems to be because of a bad, or worn, rubber gasket.
Posted on Jan 02, 2010
Water leaking from somewhere on my bissel quicksteamer model #1970
This is not an easy one for us to offer advice on because we cannot see it. There are a lot of places that can leak water and there are a lot of parts that can wear out. You need to check the hoses and connections on all the tanks and spray bars. At least you can get parts for it now: http://www.vacsite.com/en/bissell-parts-1/bissell-parts/1970-quicksteamer.html
Apr 22, 2016 | Vacuums
Why wont my bissell quicksteamer **** up the water?
Hey Kailyn, having no suction is a problem. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1092&cid=ccsocial
Jan 12, 2013 | Bissell 1770 Quicksteamer II Upright...
What's your problem? how to replace nozzel for bissell quicksteamer
The User Guide for your Bissell 1770 QuickSteamer can be found here:
http://canada.bissell.com/images/UserGuides/1970-2080_English.pdf
Available replacement parts may be ordered online here:
http://canada.bissell.com/Products/p/1770+quicksteamer/ak/replacementparts/Product.aspx
Was not sure if you meant you were having difficulty with actually removing and replacing the nozzle? Please reply if you need further asistance
Oct 27, 2011 | Bissell 1770 Quicksteamer II Upright...
I have a Bissell Quicksteamer plus model # 1950 and when I plug it in it begins to heat the water then trips the circuit. Can this issue be corrected?
Have you cleaned the tanks recently? If not do it.
Remove water from the solution tank and collection tank.
Keep the tanks open and allow to dry in sunlight.
If you can, remove the solution tank and see whether there are any leakage signs where the tube connects to the solution tank. If there are, use an adhesive that can withstand heat and stops the leak.
You can also contact Bissell consumer service on 1-800-237-7691.
Aug 07, 2011 | Bissell 1960-3 QuickSteamer Plus Upright...
Need instruction book for bissell model 1770
Information on your Bissell QuickSteamer 1770 can be found here:
http://canada.bissell.com/Products/p/1770+quicksteamer/Product.aspx
The User Guide for the 1770 /1970 Series is here:
Apr 13, 2011 | Vacuums
Where can i order a quicksteamer plus 1950 clean water tank?
I had a look at the Australian variant of this model and located parts number 407-0931 Clean Water Tank.
My best suggestion is that take this part number and contact your local Bissell Service Center, go to the Bissell International website to locate information for your country.
May 26, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
No suction
Bissell has made this model along with all of the older cleaners obsolete along with the parts for them. I would buy new.
Sep 05, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
Bissell 2080 QUICKSTEAMER Upright Vacuum Logo
53 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
