Bosch logixx tumble dryer WTS86516GB/03 reset button
Is there a reset button on this model
  • 1294 Answers
SOURCE: Bosch logixx 1600 workshop manual
Look for user manuals at http://www.user-manual-search.com
Posted on Mar 14, 2008
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
SOURCE: Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Posted on Nov 29, 2010
The heating element has blown - this has happened to mine on 3 occasions all covered under extended warranty - regularly occurs about once per year. Now hear is the interesting bit - do you have a microwave near the unit ? If so move it because our Bosch engineer said that the microwaves can have an effect on the unit. If it is true then I will know next year about this time !
SOURCE: Is there a reset button
is there a way of resetting the programme on the machine
Posted on Jun 30, 2011
Hi. My tdvcw bush tumble dryer turns but won't heat up. There's no reset button. Also the temperature light is flashing
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
If your tumble dryer isn't heating up, it's likely that the heater may .... helllo, i have a bosch dryer it works ...
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
For all your tumble dryer spare parts go to http://bit.ly/1LJTuT6 In this video, Rory shows us how to change the ...
Jan 25, 2016 | Dryers
Tumble dryer manuals
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
When you open the link, half way down the page you'll see the following, "click here to download instruction manuals (launches in a new window)"
When the new window opens, type in "WTA3606GB" in the search box and press<GO>
The manual will be in a pdf document format. You can download it or open it and then save it- the site is free.
Dec 04, 2013 | Dryers
Bosch logixx 10 tumble dryer
This is not a good sign. You should check to see if the door switch is bad. If it is not that then the controller needs replaced.
Jul 08, 2013 | Dryers
NrO fault code on bosch logixx 8
nrO is child lock. Hold start button for 5 seconds to remove.
Dec 07, 2012 | Bosch Logixx WFT 2806 Front Load...
Have a Bosch logixx condenser dryer. key sign on screen
You have activated the child lock, basically you have held the start button for over 3 secs. turn the dryer to the cycle you want and keep your finger on ther start button to deactivate. If this doesn't work you may have a module problem. Double check your manual for child lock info. if no module go to link and enter you Enr number.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Jul 02, 2010 | Bosch Dryers
Mar 17, 2010 | Bosch Washing Machines
Time work problem
If it is relatively new, then my advice to you, is to contact the service agents, and get it looked at under guarantee.
Please rate my solution.
Thanks.
Sep 17, 2009 | Bosch Logixx WFT 2806 Front Load...
Does the Bosch Tumble Dryer WTA3003GB/01 have a trip reset button
YOUR DRYER HAS A FUSE AND NEEDS TO BE CHECKED. SEE IF IT IS LOCATED SOMEWHERE WHERE THE POWER CORD COMES IN AT. IT SHOULD BE CLOSE TO THE MAIN POWER COMING IN OR MAYBE EVEN IN THE CONTROL PANEL AREA.
Apr 10, 2009 | Dryers
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
