Question about Air Tools & Compressors
Airmaster compressor manual
Looking for a source for a manual for my Airmaster Tiger 8/36 Turbo compressor. Hard or electronic.
2 Suggested Answers
  • 58 Answers
SOURCE: I have an airmaster 8/30 turbo compressor. When i
hi disconnect the pump outle pipe at the cyl head run it you should get air if not take the head off 4 bolts turn over by hand up dn ok ckeck valves 4 broken spring /ok n ok remove barell check 4 broken rings /piston has to be 1 or more of these hope this helps merlin v12
Posted on Aug 19, 2009
Turbo not boosting opel corsa 1.7dti club bakkie
In the old days the turbo would boost as soon as the engine speed was sufficiently high and any over pressure would be dumped by a relief valve or controlled by a wastegate.
In these modern times of electronics the turbo wastegate is normally open instead of normally closed so there is no automatic boost. The engine management system decides when there will be boost and how much boost there will be.
Turbo chargers are amazingly reliable unless they are abused or there has been foreign matter ingress. When looking for the cause of no boost it is wise to disconnect the intake trunking and turn the compressor vanes by hand to ensure all is well.
Disconnect the vacuum line to the wastegate servo and apply suction to the servo to ensure the servo, the linkage and wastegate is moving and in good order.
The next stage is to examine the vacuum line and connections back to source and then ensure the vacuum supply is adequate.
If all is found to be well with those physical checks the cause of no boost is either the failure of one of the vacuum switches (or the electrical wiring or connections to them) or a fault condition exists that has caused the engine management to decide not to provide turbo boost.
In that case diagnostic equipment will be needed.
May 21, 2016 | Opel Cars & Trucks
I am looking for a 1993 tiger 900 workshop manual as cheap as poss can you help Paul
Here is a site that offers a 1993 Triumph Tiger motorcycle repair manual.
The price is $ 35 . This seems resonable for a repair manual.
Good luck
http://www.bikebandit.com/1993-triumph-tiger-motorcycle-repair-manual/c/a642315?mg=11964&t=1
Jul 06, 2011 | 1993 Triumph Tiger
I have an airmaster 8/30 turbo compressor. When i switch it on it runs ok but no pressure builds up and no air is going into the tank can you tell me what is causing the problem. many thanks R Thompson
Aug 14, 2009 | Clarke Air Tools & Compressors
Airmaster 15/50
hi dave your non return valve is passing air,you will find this if you follow the delivery pipe from your pump to your tank ,where it connects to the tank this is your nrv,there will be a hexagonnal plug ,BEFORE REMOVAL EMPTY YOUR TANK COMPLETELY.remove plug,inside you will either find a spring and a synthetic seal or a spring and sphere , if its just like a rubber like seal just replace the seal(sometimes you can simply turn it over),if its the ball type,then you will have to replace the whole valve,available from your local
compressed air service agent if you have any trouble finding one localy then contact myself at
service@icasair.co.uk
Mar 24, 2009 | Air Tools & Compressors
Unable to uninstall tiger woods '03
Push uninstall programs under the control panel. If this doesnt work, then push my computer, go to you main hard drive, go to program files and delete the folder that is named Tiger Woods. Hint- It might also be hidden in a file called EA or EA Sports.
Mar 20, 2009 | EA - Electronic Arts Tiger Woods PGA Tour...
Air Tools & Compressors Logo
313 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
