Question about Cobra 29 LTD CB Radio
I have a Cobra 29 LTD that wil power up, but won't talk or receive.
    Genius:
  • Cobra Master
  • 1,795 Answers
Lot of possibilities but the one I'm thinking of is , did you buy this radio new or used. If you bought it used there is a chance that the person that owned it last broke it and couldn't fix it so he sold it to you. Now you see the problem and want to fix it but don't know where to start. ok ,here goes. Check your antenna system A bad ground will will give you this problem.Make sure you SWR is low. then if that doesn't cure it open the radio and check for bad solder joints. Flex the radio and see if ti comes on. Check to see how it will cost to fix it ,then go buy another one.Only if no other options work.
Posted on Nov 04, 2013
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
Wow. That's not at all a solution to what this guy is asking. And why all the caps??
The one point jm77437 has that is correct is that you do not set the radio, you set the antenna. The rest is blah blah.
Here is how you tune your antenna for you radio. First off it depends on what kind of antenna you have. most fiberglass antennas have a tunable tip to adjust the height of the antenna. Metal whips either have a collar at the base that the whip will either slide up or down in to adjust the height. The other type of metal whip's you have to physically clip to shorten the antenna, you must be careful with this type because once its clipped, that's it. You cannot add what you cut off.
I am going to give this example using a metal whip with an adjustable collar.
First after your radio is hooked up in the vehicle, drive to an open lot. Buildings and other structures can cause extra reflection. turn to channel 1. Flip the meter to CAL. Key the mic without talking. Now turn the CAL knob up until the needle reaches the little upside down triangle all the way to the right marked CAL. Now you have just celebrated your radio for your setup to measure you SWR. Now while still holding the key, flip the meter switch to SWR. The needle will move, and where it stops is your SWR reading. The lower the better. Anything under 1.5 is considered really good. But still, the lower the better.
Make note of what your SWR was on ch 1.
Now flip to channel 40. Repeat the SWR process. You must recalabrate each time you take a reading.
Now like jm77437 said. If your SWR reading is higher on 40 then 1, then your antenna is too long, and you must make it shorter. Loosen the collar and lower the antenna in the collar 1/4 inch at a time. check the swr each time you adjust the antenna.
If your SWR reading is higher on channel 1, then your antenna is too short. You must make your antenna longer. Do this by loossening the collar and pulling the antenna upward in the collar 1/4 inch at a time, again checking the swr each time you adjust the antenna.
What you want to achieve is having the same SWR reading on channel 1 and 40. then you have the best match you are going to get with that antenna.
If your swr is under 1.5 on all channels, you don't need to fuss unless you are a perfectionist. then by all means go ahead.
If your reading is higher then 3, or your ant light comes on, something is really wrong. Make sure your antenna is connected all the way, and the coax is not damaged.
Its important to have an appropriate SWR because if you do not, you are reflecting too much signal back into the radio, and eventually you will burn out your final transistor, and your radio will be toast.
Some tips: make sure you check the swr with the doors and windows shut. Make sure you are in an open lot. Remember to calabrate ecah time you take a reading. If you have had your radio peaked by a radio shop, and they have lowered your dead key, or have done a swing modification, then the meter in your radio will not work when taking an SWR reading and you will have to use an external meter.
Posted on Apr 24, 2009
Dodgem250
  • 68 Answers
SOURCE: Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
Posted on May 10, 2008
  • 200 Answers
SOURCE: cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Posted on Jan 22, 2009
  • 773 Answers
You should not calibrate the antenna before you install it on the car!! the antenna needs to be calibrated on the vehicle that it is going to be on. Type of vehicle, different mounts, and many other variables can change the amount of reflection you will get.
j0hn9999 did a much better job but left some info out.
Take your SWR readings on channel 1, then on channel 40.... NOW, if your SWR is higher on ch 40 then ch 1, then your antenna is too long and it needs to be shortened. Refer to the antenna instructions on how to shorten the antenna.
If your SWR is higher on ch 1 then on ch 40 then your antenna is too short. You must lengthen the antenna. Again refer to your antenna instructions on how to lengthen your antenna.
You must calibrate each time you take a reading.
Make sure your doors and windows are shut when taking a reading
Make sure you are in an open lot when taking a reading as buildings, trees and other structures can cause reflection and give you an inaccurate reading.
If you adjust the length of your antenna on another vehicle and then put it on yours, the SWR will be off. It will need to be tuned again.
An external meter is better then the one in the radio, but will need to be hooked up in the vehicle you have the antenna on.
If you are not running any kind of power, or do not have a swing kit installed, and the radio is stock, the meter in the radio is more then enough to get a correct SWR reading.
  • 773 Answers
SOURCE: cobra 29 ltd classic ant light
Your SWR is probably NOT fine. You need to use an external meter if you have had work done to the radio. Especially if you have had a swing mod done to the radio. When you do this, the dead key of the radio is lower then the calibration knob on the radio can adjust for. It will always come up lower then it actually is.
Your radio might have been fine before the work was done on it because it was putting out very little power. Now you are most likely putting out 50 watts or more. Big jump from 4 watts.
When your raise the power in a radio, you will notice more when the antenna is not properly tuned.
In most cases with a stock CB, even when the antenna is not even near tuned, you will get a reading less then 1.5 anyway.
the more power you put out, the more important it is to have a good match.
But an external SWR meter, and check it. be careful if the ANT light is on.
You might also want to check your coax, connections to it, and your antenna for anything wrong.
What color wire for talk, receive, etc. For it's 4 pin plug
different radios different pins. If you are looking to wire a cobra 29 LTD mic to a Cobra 29 LXLE its the same but to another radio such as a Lafayette it may be different.
Mar 28, 2016 | Radio Communications
My cobra 29 lx won't go off of channel 1
what else did you do to mess up this radio.
Feb 23, 2013 | Cobra 29 LTD CB Radio
I have cobra 29 LTD that will power up, but wont talk or receive.
First make sure the switch on the front is not set to PA or Weather if the unit has the weather featurre.
Then look to see if the receive/transmit meter is showing any movement in either mode.
You had a Connex board installed? I bet that is wired wrong or a wire came off in the process
Do it yourself installation or a "expert"?
Dec 07, 2012 | Cobra 29 LTD CB Radio
Why is the swing on my cobra 29 ltd with bt swinging backwards with i talk
because when you tried to modify the radio for more power and audio you turned the wrong coil and can.
Aug 01, 2012 | Cobra 29 LTD CB Radio
Cobra 29 ltd classic ant light
Apr 22, 2009 | Cobra 29 LTD CB Radio
Have Cobra 29 LTD CB Radio w/ bluetooth. Power comes on. Does not receive or transmit. What's wrong?
Sounds like the PLL circuit....... no channel synthesizer will kill the transmit and receive...... bad crystal or IC could be at fault or if someone has attempted to add more channels could also be cause.
Dec 20, 2008 | Cobra 29 LTD CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
I have just bought a cobra 29 ltd classic with a scanner ant and it worked befor on the turck it was on but now that iv installed it on my truck im not able to talk to other nor hear them
sounds like a mic problem if a wire is broken in the mic it will not let you receive or transmit common..or not to common an audio chip...
Aug 17, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
143 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
