Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Samsung le46 lcd tv sound goes down to zero and wont stay up
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Under each of the plastic buttons on the set there is a tiny push switch--the plastic button activates it---it is a momentary switch and when the button is released it should stop its function.
A lot do not--fail: vol up is worst but can be any of them. The way to prove this is get at that switch (vol down in your case) which is usually on a small circuit board---unsolder the two pins for that switch and remove it.
If problem gone you know what it was---you really do not have to replace it as the remote should duplicate all functions of these switches---in some cases the remote will not control or stop this---front controls have priority over the remote.
Posted on Dec 08, 2012
4 Suggested Answers
  • 29 Answers
SOURCE: 32 inch Samsung LCD TV has no picture
do this test, turn tv on and touch the screen if you can see light in the background it is the panel if no back light is present then it is the power board.
Posted on Mar 15, 2008
blueextc3221
  • 15935 Answers
SOURCE: samsung 27" lcd tv picture goes black, still have
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!(*&^%
Posted on May 27, 2011
SOURCE: Samsung LCD TV backlight switched off
Most likely you will need to get a diagnoses done on the set. It could be a faulty 24vdc circuit (power supply capacitors), defective inverter, or a failing CCFL backlamp.
Posted on Oct 29, 2012
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
My 19" Coby hdtv 's sound will NOT stasy .Itgoes down to zero and when I put it back up ,either remote or on tv itself ,it goes up then immediately goes back down to zero .
unfortunately the coby company has gone out of business probably because they have produced an inferior product that has had many problems, many people are posting problems with these sets. it is better you just purchase a different brand of tv and leave this heartache causing product behind.
Apr 26, 2014 | Coby TFTV1923 19 in. LCD TV
Volume goes to zero
sounds like you need to replace the buttons on the side of the tv. I can get you a part number if you will supply me with the full model code and version of your tv.
Dec 31, 2013 | Samsung LN32A540 32 in. LCD HDTV
40 samsung lcd tv problems
remove batteries from remote control and adjust volume to desired level. If the volume stays the same then there is a problem with the remote. If the volume lowers again then the problem is with the TV. the volume button on the TV or on the remote may be malfunctioning. Hopefully it will be on the remote. If it is the remote, take it apart and clean it with damp cloth. after allowing it to dry, re-assemble and try it out.
Sep 12, 2013 | Televison & Video
Samsung le46 lcd tv sound goes down to zero when turned back up returns to zero imediatly bar stays on scrreen showing zero
Listen carefully:
The volume down is likely bad on the set, this happens a lot and I will explain why and what needs to be done.
All sets with exterior controls, volume, on/off you name it behind each plastic button is a tiny switch---a push switch that when released stops.
Bad ones develop not from age but poor quality,,,,that is a momentary switch, as long as held it should function and when released stop.
Be thankful it is not the sound UP as I have seen that, Menu, you name it.
Now to the proof and the solution, Someone has to gain access to that switch under that plastic button and remove it from the small circuit board it is soldered into---2 to four solder connections and remove the switch.
A ten year old with a soldering iron can do it.
With it removed power set back and see, if problem gone you have a few choices (really no choice if it was me) order and replace the entire board with all the buttons affected or DO NOT PUT THE BAD SWITCH BACK AND just use the set with the remote.
For the technical minded first the reason a remote will not stop this is buttons on the set have priority over the remote functions and YES you can test the bad switch and find it that way---I have seen ones not being pressed that read as low as 3 thousand ohms or less and that is bad=====there should be no reading across the two pins that are for that switch itself.
Let me know if you have questions, PS none of them sell the individual parts you have to buy the same poor quality board with another set of switches on it.
Dec 11, 2012 | Samsung Televison & Video
Oct 28, 2012 | Samsung LE-46A566 46 in. LCD TV
Sound
try to replace the (-) volume button it is defective so the volume will auto down..
after you replace that 100% works fine..
Apr 27, 2012 | Audiovox PLV16081 8 in. LCD TV
Our TV has been great. Have owned it A little over 2 years. Just now the Volume line appears on the screen and the volume goes to zero without anybody touching the remote. The volume line stays on the...
Check the tv pannel manually control on the right,see if it work.Then it ur remote tries take it aparts clean it with some alchol with a Q tips there a screw under the batteries input,after that change the batteries,That one solution.The other have to take ur tv apart to change the sound board.
Sep 27, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
HAVE A SAMSUNG LE46 HI DEF TV. THE TV WON'T SWITCH ON PRESSING THE ON BUTTON BUT IT JUST KEEPS CLICKING AND WON'T SWITCH ON
first of all, is the tv plugged in?
make sure its plugged in and make sure the cord is connected to the tv securely.
that could be the reason why it wont turn on.
if that is not the case, your tv is probably ruined.
cheers.
Aug 15, 2009 | Televison & Video
New samsung series 6 lcd tv brand new, but has a problem , the sound keeps lowering down to zero by itself for no reason, auto volume is off??
When watching football on my samsung le40a656 there is ghosting behind players. It is connected to a sky box via a scart lead, any idea's
Jul 01, 2008 | Samsung Televison & Video
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
70 people viewed this question
Henry  Thomas
Henry Thomas
