Question about Epson Stylus C86 InkJet Printer
Printer not printing corrrectly
It appears to me that 2 of the 4 sponge pads (I think the numbers are correct) beneath the parking place are missing. Can these be replaced?
  • jtbmph Jan 25, 2009
    Thank you for your help. I think I've got it whipped now,,even though it's taken me a while to get at it.
    Novelist:
  • 140 Answers
Yes they can. They are there to clean the bottom of the ink cartridges as they come across. To tell you the truth they are only made of material similar to what you find in alot of carburetor air filters in lawn mowers or the typical screens you find for air filters in central air and heat.. Just go to Lowes or Home Depot and show them the little sponge and they can match it to something that will help you for a long long time. God bless.
Posted on Jan 12, 2009
Canon MP600 printer not printing correctly
The cleaning sponges are on a spingy pad, which can get stuck because of the old ink get a bit gunky. This can cause error 5101.
Try this...
Open the bonnet, use a torch, gently tug the ink carriage to the left of the rails.
Clear any paper jammed in the right of the ink carriage.
Lightly press the cleaning sponges down, (I used a long pen)
Restart the printer.
Jan 12, 2012 | Canon PIXMA MP600 all-In-One InkJet...
Canon i9900 - keep getting message - ink absorber almost full. Where is it - how do I get at it and what do I have to do. Also one end of sponge strip has come loose - how to I get at it to put it back...
The ink absorbers are white pads. they reside at the bottom of the printer. The entire chassis needs to be removed and new pads fitted. Then the software needs to be reset to remove the message and return its counters to zero. The black sponge is also replaced at the same time. To get to the right end (i presume thats whats your referring to) just start the printer so you hear the carriage move and plull out the mains plug. Now the carriage is unlocked and you can move it easily. Just push the sponge back down, it should stay in place. The job is best left to a canon specialist as the chassis removal is a bit of a job. Good luck.
May 16, 2011 | Canon Office Equipment & Supplies
My printer said the waste ink absorber is full and need to be replace with a new one. where actually is the waste absorber and how i can replace in by my own?
The waste ink absorber is at where the cartridge rests.When you turn off the printer.Its a sponge pad assembly,which soaks the waste/extra ink from the cartridge while printing.When this pad is full of ink and it cannot soak more ink this waste ink absorber replacing indication comes up.To replace this the top portion of your printer needs to be removed.Its fitted with screws. Once the top is out you can replace the sponge pad by removing the cartridge resting mechanism.This sponge pad is stuck -up by double tape,you will need to pull that up slowly towards you and reinsert new pad in same manner as the old was placed. ------------------------ But there is also a reset procedure to be tried to clear the waste ink absorber error.Try this reset procedure couple of times and see.If this error goes away you can use your printer without replacing the pad. The procedure is as follows:---- 1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.In your case.-------------------
The number of the Reset.
button pressing.
LED Function Remarks.
0 time Green Power off.
1 time Orange Service pattern print.
2 times Green EEPROM print.
3 times Orange EEPROM reset.
4 times Green Waste ink counter reset.
5) Turn off the printer.( it must be turn off)
then turn it on again.
After you press Stop/Reset button 4 times the waste ink counter gets reset after that turn off the printer and turn it on.And then see.If the error is gone you can continue using your printer.Take care you read the instructions properly.If you forget any step by mistake,start with step1 again,.-------------------- In most of the cases this reset helps.Try it good luck.Thank you.
Jan 31, 2011 | Canon PIXMA MP150 All-In-One InkJet...
The waste absorber is almost full. Where is it? Where do I get one? How do I change it?
The waste ink absorber is a small sponge located right underneath where the print head parks when the printer is at rest. Difficult to get at!
However, Open the printer lid as if you are going to replace a cartridge. You have to be very quick now. As the print head moves over to the left hand side of the carriage pull the power cord out . The carriage will now stop well away from the parking area and you will have enough room to work. You will get ink all aover your hands so be propared.
Get some heavy duty kitchen towel (the kind Costco sells) and a bright lamp. Use the lamp to illuminate the parking area (it's normally under the cover so it's always a bit dark) and yu should see the sponge all black and yukki. Use the paper towel and press it into the sponge. Do it over and over again with a clean bit until the towel is coming off fairly dry (it can take a while).
When you think you have it clean, power the printer up again and see what happens. You may still get the error message but the printer should work. If it doesn't, you'll need to reset the message. Do a google search on resetting the message as I can't remember what it is.
Sometimes, you can get the piece of sponge out of the printer with tweezers or watchmaker's pliers. Wash it under running water until it is clean then dry it as best you can. You will still have to mop dead ink out of the sponge's home and you may have to use damp paper towel initially. Once you think it's all clean wriggle the sponge back into place and carry on as aove.
Good luck
Nov 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Epson 78900, black smudges on right end of each line printed ...
There is some '' absorbing pad'' at some strategic places in your printer, when you print too much after a while those pad, and head cleaning pad gets dirty and trouble start. Its a bit of a job, removing all the clip to open the cabinet, also dont place those pad in the water they grew like tampax. Replace it with dry sponge... Does it make sense to you?
Oct 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Mar 26, 2009 | Epson Stylus C66 Inkjet Printer
Help i cant print
Error code 5100 refers to blockage along the print path. While this could be a number of things, simple remedies may include lubricating the slider rod where the print head moves along. This could be as simple as a drop of oil, cleaning and checking no paper bits or accumulated dust/ dirt or grime. Another area to check is the waste in pad. This would be the white receptacle below the print heads when in park position. On certain instances, the sponge may be dislocated and would simply require moving back in place. At other times, there could be obstruction blocking the print heads resting in the correct park position. This again could be dirt,grime, bits of paper, paperclips, staplers, or even gummed up or dried ink.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Print cartridge "missing"--NOT
Problem:
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Door A not closed properly. - Open and close door A, then power cycle the printer and check for the error again.
2. The rails that the print cartridges slide in are misaligned or bent. - Remove the Transfer belt and all print drums, then check and re-align print drum rail guide. Then reassemble and verify proper operation.
3. Interlock actuator tab for the front door is broken off. - Check the interlock actuators on the front door if misaligned or broken then replace the front door, if they can be reconstructed then repair. Otherwise call for additional parts.
4. Cable connection to the Engine control board is not seated properly or fully. - Check all cable harness and wires to the Engine control board and make sure proper connection is made.
TROUBLESHOOTING TIPS AND HINTS:
Check all media trays, access doors, and front cover for proper closure and interlocks being disabled.
Apr 01, 2008 | Xerox Phaser 7700 Laser Printer
I have a Canon Pixma IP 5000 inkjet printer and am using Mac OS 10.3.9. It has 5 ink cartridges: 2 black (3e and 6) and one each yellow, magenta and cyan. I use it all day every day. After printing...
Thanks for getting back to me.
Sorry this ain't a solution but it seems to be the only cash-free way to contact you. No problem not solved - though I have tried everything. Dismantled the printer; washed, dried and replaced the waste ink pads; washed the print head; blew compressed air through the print-head sponge; replaced the cartridge 3 times; printed hundreds of test prints. I can't think of anything else to do and so I think the only solution is to replace the printhead (probably not even available) or replace the printer. The latter is looking most likely.
Feb 10, 2008 | Computers & Internet
Paper feed problem
The fault is the paper stop sensor is broken. Have the same problem myself. I don't think there is an easy solution to this as the sensor arm will have to be replaced and I think the m/c would have to be stripped down to do it. Nice to know if anybody has any ideas though.
Nov 09, 2007 | HP PSC 2355 All-In-One InkJet Printer
Epson Stylus C86 InkJet Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
