Question about Logitech Webcam
I need to reinstall my cam after crash but i do not have the disk
Above
  • DEKR
    DEKR May 11, 2010
    If this is a cam with a cd you just need to plug it in and run cd.
    If not you can do a add new hardware and follow the steps and windows and internet should find you drivers.
    If not you can go on the cam website and download drivers.
    Hope this helps.
    President:
  • 8,637 Answers
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 15, 2009
My HP 8020N is beeping with some blue instructions, it crashes and beebs then repeat the same thing when trying to rebooth
You are experiencing what we affectionately call "The Blue Screen of De##h", which is causing the PC to crash and reboot in a never-ending cycle. There are a few things that you can try to fix the situation. The first, and easiest, is to press the F8 key during bootup and try to go to SAFE MODE. If you can do that, then you can go to SYSTEM PROPERTIES under COMPUTER, select the SYSTEM PTOTECTION tab, and click on SYSTEM RESTORE. This will allow you to roll the computer back to a previous configuration, since it is likely that the crash could be caused by a corrupted or failed update. If you cannot get to SAFE MODE during bootup, you options get more limited. Most PCs today do not come with a Windows Installation disk, so using that and booting in the REPAIR area is not likely an option. This leaves you with either reinstalling using the recovery disk set (if you have one) or with the recovery partition. The downside of these options is that they overwrite ALL information in the disk, meaning all of your personal files will be gone. What you CAN do if you have access to another desktop PC is to shut down you computer, remove the hard disk, and install it as a second drive on the other desktop. It won't boot to the disk, so it can't crash. But you will be able to see the file structure on that disk and can recover personal files to a USB stick or other external media before replacing the disk in your system and using the recovery method(s) described above.
Mar 05, 2015 | HP Computers & Internet
Old machine, trying to rehab for daughter. Turn on, seet Toshiba screen, then see "Disk read error, cntrl+alt+del to reboot"
You have one of two problems. Either your operating system crashed and you will need to get windows reinstalled on the computer or your hard drive crashed.
If the hard drive crashed you will need to replace the hard drive first and then also reinstall windows.
In both cases it is needed to reinstall windows.
This is probably something a computer technician should take care of.
Mar 06, 2011 | Computers & Internet
My system crashed. Won't reinstall windows
Do you need anything that is stored on the crashed hard drive? If so, you need to get an adapter for the drive and connect it to a desktop pc as the 'd:' disk. then copy any files you can access that you need saved.
Re-install the drive into the laptop, use "FDISK /MBR" from a floppy drive or a USB drive set up as a boot disk to re-partition it, and install the master boot record, and then boot the CDrom to install your operating system afresh.
The error message you are getting is caused by the 'restore' program trying to use the C: disk programs, and they are not there. I think you may have a bad hard drive, as usually the programs will be found.
You need to find out if the disk is really really bad or just needs to be re-formatted. Follow the above steps to determine if you need a new drive or not.
tom
Jan 18, 2010 | Computers & Internet
Crashed hard drive on emachines T5026
Pardon me, but NO! The statement, "two things are responsible for booting up computer RAM and Hard Drive" is simply not true.
A hard drive crash COULD cause the symptoms you describe, but that is more indicative of a virus infection. When you say the XP reinstallation disk would not start it exactly how did you use that disk? Attempt to use the repair console? Boot directly from the disk? Attempt reinstallation of the whole operating system? If you attempted reinstallation, do you also have the specific drivers for all of the components E-Machines used when they built your computer (you will need at least some of them.)
Post again with some more details about how you used the reinstallation disk.
Feb 24, 2009 | E-Machines eMachines Desktop PC
I want to crash my computer and reload os and software
you dont need to crash your windows all you need to do is to reformat your hard disk and reload the operating system .
Dec 08, 2008 | Computers & Internet
X6570
printer did work with computer before it crashed.
Oct 19, 2008 | Lexmark X6150 All-In-One InkJet Printer
Ive lost my pleomax pwc-3800 installation disk
dear sir/madam
i have a problem to my computer co'z i lost my installer for my cam pleomax pwc3800 pls give me a solution for this...
thank's and best regards.
May 06, 2008 | Samsung Pleomax PKB-7000X
Logitech Webcam Logo
19 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
