Question about Dryers
Kenmore 90 Series ~ Model # 66912690 Electric Dryer, spins but does NOT heat, any suggestions what the problem could be?
  • 5,911 Answers
The following link explains the dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Make sure you perform all component checks with the dryer UNPLUGGED. Dangerous voltages are still present inside a dryer even with the unit turned off.
Pay particular attention to the paragraph that discusses proper dryer ventilation. Most dryer heat related problems are attributed to poor ventilation that leads to dryer overheating to the point of failure. If you can't remember the last time you had your ventilation checked or cleaned, I would recommend you do so before replacing any failed components. Failure to do so may result in undesired drying results and premature failure of any components you have replaced.
The most common cause of dryer heat failure is a blown thermal cut-out (TCO). This component acts as a fuse and will blow when an overheat condition occurs. If it is determined that the TCO is bad, it is strongly recommended that you replace the hi-limit thermostat at the same time. Failure to do so may result in premature failure of replaced components. In many cases, the manufacturer sells these parts as a set (more cost effective to purchase this way, too). Both these components are located on the heater box adjacent to the heating element.
To access, remove the lower panel under the dryer door. This is accomplished by inserting a putty knife along the seam at the top of the panel about two inches in from each side. There is a retaining clip that needs to be depressed to release the panel. With the panel removed, the heating circuits are located on the right hand side under the drum. You can view drawings of your dryer at searspartsdirect.com by entering your model number. Use model number "110.66912690" for your search criteria. The heating circuits are listed under the "Bulkhead" heading. The heating element is listed as item number 14. The thermal cut-out is listed as item 47 and the hi-limit thermostat is item 48. NOTE: You can find the TCO and hi-limit thermostat sold as a set at appliancepartspros.com as part number AP3094224 (Your Kenmore dryer is manufactured by Whirlpool). This could save you some $ if one of these components is your problem.
If you have questions along the way, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 13, 2009
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: kenmore 90 series, model #66912690/stock66912
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 12, 2010
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
AIr does not heat up...changed the heating element and still no hot air. I have a Kenmore 90 series model#66912690..perhaps it is the thermostat? Where and how would I trouble shoot for that?
very possible thats a thermo has gone bad, with a power meter you can check for continuity threw the thermostats located atopp and below the heater itself.
Oct 13, 2010 | Kenmore Dryers
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
Electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
May 10, 2009 | Dryers
KENMORE DRYER MODEL NUMBER 66912690 WONT HEAT
Check the voltage at the terminal block where the cord hooks up for 220 volts.
Remove the rear panel and check the thermal fuse located on the upper portion of the heat canister.
Check the Hi-limit thermostat on the bottom portion of the heat canister.
Check all the wires for a burned or loose wire.
Check continuity of the heating element.
Mar 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer starts, then stops. Heated motor smell
First CLEAN out the lint, not just in the mesh screen, but also by opening up the dryer to check for lint around the motor, and the manifold that connects from the drum to the outlet tube. Open up the manifold, carefully, remove lint, and REPLACE the heat sensor/temperature thermocouple that is on the outside, and has a protruding point into the manifold ($20 or less). If the drum spins when you start the cycle, it is NOT the motor! The burning smell is probably LINT that stuffed into the outlet pipe and manifold.
I have cleaned the outlet tube, manifold, and areas under/around the drum for my dryer, and my rental properties and "fixed" the problem. If it still turns off, then get the correct replacement sensors and replace them. DO NOT open the heating element. The wires inside are fragile.
Sep 08, 2017 | Dryers
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
493 people viewed this question
Top Dryers Experts
