Question about LG WM2050C Front Load Washer
Washer leaks water on the floor. I checked all hoses and filter basket and found them okay. Suggestions? LG WM2050C
    Top Expert:
  • LG Master
  • 9,472 Answers
Remove the bottom kickplate and run a load to look for the leak.
Posted on Dec 07, 2012
2 Suggested Answers
SOURCE: Leaking water from the bottom
Was this problem solved?
Posted on Dec 17, 2010
We have a LG WM2050CW and today after it went the rinse cycle it drained all over the basement floor, underneath the washer and then came out of the door.
sounds like you might have a broken hose or a loose hose. remove the back panel from the unit and inspect the plumbing. also -- while you are doing the inspection - pull the pump screen/drain plug and clean out any debris that might be in there ( you will need to do this sometime anyway ).
if you are still having troubles -- please feel free to write me back here and I will do my best to walk you through it.
c...
Feb 16, 2011 | LG WM2050C Front Load Washer
Had this only six months, water all over the floor. I opened the manual and, because the manual suggested it, cleaned out the inlet and drain pump filters (they were both clean). The problem appears to be...
Are you using 'HE' DETERGENT? High Efficiency detergent? And you should only be using about 2 tablespoons of detergent in a full load. Too much detergent, especially non-HE causes way too much suds which percolates out the vent in the back and onto your floor.
Jun 29, 2017 | LG WM2050C Front Load Washer
Replace washer for hose - washer leaks
You have to determine if the water is coming from the hose connections. If not, check that the water supply that feeds into the basket hasn't been moved out of place. Is this a new washer? I have seen cracked outer tubs-they are just plastic.
Nov 08, 2009 | Whirlpool Washing Machines
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Water leaking on floor at right front corner of
check the door rubber for any tears,this is also called a boot glove.
Jul 14, 2009 | LG WM2688H Front Load Washer
Lg frontloader, washer is not getting sufficient water. hose is okay, is there an internal filter we can check?
Plug off the wall. Unscrew the hoses that bring water to the machine, check the fine meshes on hose as well as machine, clean out well with tooth brush (not yours), see that pressure is good in your wall socket. Refit carefully, check for leaks.
Feb 26, 2009 | LG WM2487H Front Load Washer
LG WM-2277HW Water overflowing from soap drawer (compartment)
look for port inside top area of basket where water comes in may be plugged with same junk found in pump
May 28, 2008 | LG WM-2277HW Front Load Washer
Washer leaks small amount. DIY fix: check hoses and ???
Wires found in hose!
When we turned washer on it's side, we found the hose from the pump to the basket had been pierced by two stiff curved wires, still embedded in the hose. Water was leaking around the wires. Wires had come out of an underwire bra! Dealer had only heard of this once before; on his own washer!
MORAL: handwash your bras, ladies.... or pull those wires out each time.
Apr 12, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
LG Tromm hot water only
i have found the water inlet valve bad and also the main control board can cause it
Feb 24, 2008 | LG WM-2277HW Front Load Washer
LG WM2050C Front Load Washer Logo
348 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
