Question about Refrigerators
My Dometic RM 3663 will start in ac mode, but soon switches to dc mode. What causes that?
When my motorhome is plugged into 30 amp, I can click on Auto and the refrig will start in ac mode. But shortly thereafter it will switch to dc mode. What causes that?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Check the fuses
Posted on Dec 08, 2012
5 Suggested Answers
  • 36 Answers
SOURCE: dometic refrig,curcuit boards
thats normally a problem of either parts wear and tear or spiking in the the AC line ... if something like a water pump or something that turns on and then off suddenly is on the same line as the refridgerator it can cause such a problem also if the wires in the wall outlet or panel box have begun to run slack it can cause such problems as well ....
Posted on May 19, 2009
  • 68 Answers
SOURCE: Norcold DE704D won't switch to AC
http://www.thetford.com/LinkClick.aspx?fileticket=slRtJeja7H4%3d&tabid=497&mid=1316
This link will help with testing and resolve your problem. Can not resolve without these tests.
Thanks for using Fixya
Jerry
Posted on Mar 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Dometic refrigerator model RM 2193
Hi and welcome to FixYa, I am Kelly
Operators manual:
http://www.gas-refrigerators.com/pdf/RM2193-manual.pdf
Parts manual:
http://www.scamptrailers.com/Portals/0/Dometic_Refrig_RM2193_PartsList.pdf
If you look at the last page of the parts list (page 10) it is showing a thermostat across the Black and white wires.
There is not a fuse that I can see. The fuse has to be external to the unit. You should be able to read continuity (resistance) of the AC heating element at the power cord with the AC switch ON.
AC Power source must be removed to perform resistance checks.
No continuity there are 2 possibile failures (Other than wiring)
1. AC heating element
2. Thermostat.
Thanks for choosing FixYa,
Kelly
Posted on Jul 22, 2011
Testimonial: "very clear answer to my question i determined that the AC heating element was at fault. no connectivity as suggested in the question. "
motor1258
  • 6674 Answers
SOURCE: I have an old RM
Easiest and cheapest solution I see is to by a simple 12 Volt toggle switch and cut one of the wires from board to 12 VDC element and run it to a toggle switch mounted inside near fridge. One terminal on switch will be wire from board, and other terminal on switch will have wire going back to wire cut going to element. Simple and cheap , on, off, solution, just be sure to use heavy enough gauge wire, and add an inline fuse if you want for added safety.
Posted on Sep 18, 2011
Dometic refrigerator model RM 2193 for RV works only in the DC and LP Gas mode. two days ago the AC mode was still working and stopped yesterday (outside temperature was about 40 degrees...
Operators manual:
Parts manual:
2. Thermostat.
Kelly
Jul 22, 2011 | Dometic Refrigerators
Refrigerator will not cool on electric or gas. When plugged in, it keeps trying to switch to gas. We switched it to gas but it would not stay lit. Checked wiring and found a blue wire disconnected and a...
The blue wire disconnected and the 30 amp fuse being pulled is typical of a DC circuit problem. What concerns me is the fact that someone had to put a 30 amp fuse in a 3 or 5 amp circuit. Maybe you meant to say 3.0 amp.
The unit uses a 5 amp fuse on J5 of the main board for AC power and a 3 amp fuse on J1 of the main board for DC power.
See page 17 of this manual:
http://www.gas-refrigerators.com/pdf/RM2852-manual.pdf
For part numbers of parts see Appendix A in this manual:
http://www.dometic.com/c415ec17-8004-4fef-9a97-c68e601bf593.fodoc
You will need to use this manual to troubleshoot:
http://bryantrv.com/docs2/docs/1252service.pdf
See step 3 page 2 to start... where is says Operation you have to perform the testing steps listed below Operation.
Operation
AC Volts
Fuse
Heating Element
Wiring
Lower Circuit Board
From the hip given the fuse was removed I would suspect the heating element but.. follow the sequence above.
Kelly
May 18, 2011 | Dometic RM2652 Refrigerator
Our dometic RM 2350caravan fridge smells like amonia when switched on to ac or dc power. It wont get cold. Help please.andrea
Hi, you have a freon leak in your system, with the caravan refrigerators they use amonia as a cooling media. You need to either have a service person the knows this system or purchase a new one. thanks.
May 18, 2011 | Dometic Refrigerators
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
Genset starts and runs fine but the 30 Amp circuit breaker trips as soon as a load (AC) is applied. Started right up, ran half a day, but now when it starts the minutes I click on the ac the circuit...
What about when you have it powering the motorhome, without AC on, does it trip then? Do you have anyone you know with a multimeter and knows how to use it? How about buying a plug in voltage meter at a hardware store as a good start. You simply plug it in to a receptacle in your motorhome and it will tell you the incoming voltage and they are not very expensive. That will help diagnose generator problem.
Nov 01, 2009 | Watts Onan Portable Generator - 4000 ,...
1994 mountainaire motorhome AC
Are you sure they are getting hydro & 12 volts DC? Check all breakers & fuses. You should at least hear clicking at units when turned on. Not likely both would go like that. Does your unit have a switch to go from one to other or both? What brand & type of thermostat are you using?
Aug 04, 2009 | GE Quiet-Aire Ductless Split System Air...
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
