Question about Whirlpool RCC3024 Electric Cooktop
Whirlpool Flat cooktop burner not heating up
I have a whirlpool flat cooktop (Model: GJ8640XBB0). Of the 4 burners, 2 of the front burners are not heating up and the Hot Surface Light is always "ON" irrespective of whether the stove is used or not.
I tried to turn off the circuitbreakers and then switched back on. But no use.
Any suggestions would be of great help.
Thanks in advance!
  • krexternal Mar 05, 2009
    I normally clean the knobs once a month and even tried turning the knob from one side to other. It still does not work:(
  • Anonymous Mar 31, 2014
    Replaced a switch in back that fell apart but still don't work
Try cleaning the knobs. I did the same thing you did (turning the circuit breaker off but that did not solve the problem.
My wife just tried turning the knobs and that seemed to work. It appears that one of the knobs may have been so sticky that the though it's in the OFF position it thinks it's still ON.
Posted on Mar 05, 2009
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
My right front burner has stopped working.
no solution - just wanted you to know that I have had this model since 2004 and had to replace this burner twice under warranty and twice after that. It broke again 2 years ago so I just cook without it now. Will be replacing the cooktop and am resolved not to buy Jenn-Air/Maytag/Whirlpool products again - convinced it is a element design problem.
Feb 26, 2011 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
We have a whirlpool gas cooktop, Model SC8720EDB, Serial FMG1005626. When the left two side burners are lit, either one or both, the suction fan automatically cuts on. When the right side burners are...
It does this by design. It is a safety feature on this model because it was designed to have a gill module on the left side. I don't know if you can change it without replacing the two left control valves with valves like it has on the right burners.
Nov 24, 2010 | Whirlpool 30 in. SC8720 Gas Cooktop
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
Whirlpool gas cooktop will only spark on left front burner
i made this video to help you troubleshoot kitchenaid and whirlpool cooktops
Apr 01, 2010 | Whirlpool GLT3615 Gas Cooktop
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Oct 21, 2009 | Whirlpool RCC3024 Electric Cooktop
Whirlpool Cooktop Burners do not light
Hi Scott,
Please view the link and videos below.
Searching youtube can often provide many helpful videos that clearly explain how to repair such issues.
Good Luck.
Jun 02, 2017 | Whirlpool 30 in.GLT3057 Gas Cooktop
RCC3024 cooktop one burner wont heat
Hi again,
It would seem you posted anew.
For some reason I could not locate related literature for a RCC3024LD01,although there are for LB01, LQ01 and a LT01. Most of the components inthese models could be checked with the use of a continuity tester(multitester VOM/DVM). The idea is to check for continuity of eachcomponent. If we are to assume that the heating element as a likelysuspect, it is a matter of checking if the coil is continuous, that isno break anywhere in between. The test prods of the continuity testerwould be applied to the two (2) terminals of the heating element andthe tester should deflect/display how much is the resistance. Normalreading shouold be pretty low while no deflection/reading indicates anopen coil and therefore would require replacement.
These additional documents may be of help to you:
  1. exploded parts diagram;
  2. parts list.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Whirlpool electric Cooktop's one burner not heating
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Whirlpool RCC3024 Electric Cooktop Logo
900 people viewed this question
Top Whirlpool Cooktops Experts
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
