Question about Kenmore Dryers
No heat from my Kenmore 80 Series dryer MODEL/STOCK NO. 66812691
  • Kenmore Master
  • 8,220 Answers
I looked up your model. You can view parts HERE.
To get to the heater element you remove the back cover. It is located on the right and is held onto the heater housing by 2 screws. On the heater housing is also the safety limits. If either of them is tripped their will be no heat. If the heater element is fine and you do have a tripped limit I suggest you take steps to remedy any air flow problems you may have. I recently worked on a dryer just like yours with a heat problem and I made a video. I have several on youtube on my channel. Here is my home movie:
More repair info is on my blog
Posted on Dec 07, 2012
  • 156 Answers
SOURCE: Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Posted on Mar 19, 2008
  • 97 Answers
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
  • 97 Answers
SOURCE: kenmore 80 series gas dryer w/ no heat
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, and maybe an igniter all three are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new, if it doesn't then you will need to check the igniter. The igniter is attached to the end of the burner assymbly by one screw and a simple two wire plug. Inspect for breakage, and replace if needed. Happy to help, Tim.
  • 1122 Answers
SOURCE: Kenmore series 80 dryer not heating
UNPLUG REMOVE THE BACK,YOU WILL SEE THE HEATER BOX TO YOUR LEFT,THERE IS A SMALL FUSE ON THE LEFT SIDE TOP,CHECK THAT IF YOU HAVE A METER,ON THE BOTTOM HALF OF BOX IS THE HEATING COIL,REMOVE THE 2 BOTTOM WITES AND CHECK THAT WITH YOUR METER,IF YOU DON'T HAVE A METER REMOVE THE 2 SCREWS ONE ON EACH SIDE OF THE HEATING COIL AND REMOVE THE COIL,LOOK TO SEE IF ANY OF THE WIRES ARE BROKEN,IF IT WAS THE FUSE THAT'S BAD THERE MUST BE A REASON IT POPED,MAKE SURE YOUR WALL EXHAUST VENT IS CLEAR,ALSO IF YOU CHANGE THE FUSE CHANCE THE HIGH TEMP THERMOSTAT LOCATED ON THE LEFT SIDE BOTTOM,YOUR MODEL NUMBER IS INSIDE THE DRYER DOOR-MIKE
Posted on Mar 07, 2010
marka19
  • 1430 Answers
SOURCE: 80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Posted on Mar 28, 2010
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
KENMORE 80 SERIES GAS DRYER RUNS BUT DOES NOT HEAT
You have a defective gas valve solenoid. If you have an appliance repair center in you area, go to the parts dept, give them your exact model number and they should have the part you need in stock. The solenoid is easy to replace....you can do it yourself and save some money..
Good Luck,
Eric
Jul 09, 2009 | Kenmore 72802 Gas Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Mar 18, 2008 | Dryers
Dryers Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
