Question about Canon PowerShot A400 Digital Camera
Video Problems My Camera will not take pictures, I can not get it off of Video mode.
    Scholar:
  • 99 Answers
Auto Mode In this mode, all you have to do is press the shutter button and let the camera do everything else. 1. Turn the camera on.
2. Turn the shooting mode dial to Video Problems - normal_mode.gif.
3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
  • The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
  • When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
  • Two beeps will sound when the camera has finished metering, and the indicator will light green or orange. If the LCD monitor is on, the AF frame will appear green.
  • The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
af_frame_indicator_a70.gif 6. Press the shutter button all the way.
Video Problems - full_press_shutter_button.gif.net/uploads/images/full_press_shutter_button.gif" alt="full_press_shutter_button.gif" class="h_mi" />
  • You will hear the sound of the shutter when the shutter activates.
  • The picture appears for two seconds on the LCD monitor, if it is on.
  • The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
Posted on Feb 08, 2008
2 Suggested Answers
RadarRon
  • 398 Answers
SOURCE: CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
Posted on May 21, 2008
Panasonic lumix problems
Try taking the batteries out for a few minutes. They're may be a second battery for the camera clock and date. If there is, do the same. Good luck.
Aug 14, 2014 | Panasonic Lumix DMC-TS10R 14.1 Megapixel,...
How to switch from video to pictures
Push the mode button (the front button) until you see the single camera. It sequences through the whole series before starting over. The video mode is first, the camera is second. If may be different if you've set a different default mode, just keep hitting the mode button until you see the single camera.
Apr 09, 2014 | GoPro 2gb Sd Memory Card For Vivitar...
A200 faulty selector switch
Same thing happened mine. Take out battery and leave camera for a few weeks until internal cell goes flat. Switch to "stills" mode and put battery back in. You will need to reset the date and time. LEAVE SWITCH IN "STILLS" mode for ever more.
Dec 31, 2011 | Konica Minolta DiMAGE A200 Digital Camera
I am from bangladesh the problem associated with my camera is that the display dont show the view of the subject that iI want to capture and the resultant is the no picture only shows the black sheet in...
The S2 IS is a very nice camera, but is known to be susceptible to stuck shutter problems. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 12, 2011 | Canon PowerShot S2 IS Digital Camera
When in Camera mode I focus and then prepare to take the picture but the as soon as I press the switch to take the picture the LG routinely switches from Camera mode to the Video mode. Why? I cant see
Well, this is the intended function of the button unfortunately.
If you press and hold down the camera button, it toggles between camera and video.
However I'm sure you have noticed that on occasion, if you don't hold the button down long enough, no picture is taken.
It turns out to be something you just have to get used to. There is like a 2 second delay on the toggle so just don't hold it down that long. It is hard to get used to if you are used to a red eye removable flash or a slow camera button as found on many new cameras.
Here is a tip though, after you take the picture to quickly take another picture, you can fast save the photo by pressing the camera button again instead of messing with the touch screen.
May 22, 2009 | LG Dare VX9700 Cell Phone
May 20, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
CAMERA TURNS OFF WHEN IN PICTURE OR VEIDEO MODE
This problem is that your camera has shut down improperly.It has gotten out of tim.IT requires taking the camera apart and re-timing the camera to its restart position. Hope this helps jerry
Problems with my Polaroid izone 300's picture...
This is a CCD failure This is a known problem and the manufactures will replace the camera if it comes within their terms. Check out Polaroid on this
Aug 03, 2007 | Polaroid iZone 300 Digital Camera
Power/lens Problems
it seems that the lense movement is jammed. Have you dropped the camera? just have a close look from the front side of the camera, does the lense assembly seems to be pressed or moved aside by some extra preassure? if no physical disalingment is visible may be some sand or dust partical is obstructing the movement of the lense assambly. needs a help from camera repair shop.
Sep 08, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Canon PowerShot A400 Digital Camera Logo
104 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
