SOURCE: Using a Jensen remote, can't access input mode
turn on your tv, press and hold tv button, then the on/off button, it will light up then press the power button.and it turns off....hold. After holding down both for buttons for 3 secs the light on the on/off key turns back on. Release both keys and the light should stay on. Now hit the On/off button repeatedly until the tv turns off, when it does hit the stop button to save code.
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
SOURCE: URC-R6
if u have any questions about the urc-r6 then jus go to the link and u can find exactly what u need. it took me no more than 2 min to get my situation resolved.......excellent
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
