Question about Dishwashers
Hello my dishwasher will not drain after wash.
    Master:
  • 623 Answers
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Posted on Jan 12, 2009
Not draining properly
Hello, I would look for a kink or a blockage of the drain hose. Also check the drain pump belt for looseness or breakage.
Jul 30, 2014 | KitchenAid Kitchen Aid Superba Series...
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Drain pump wont stop
Hello there and thank you for choosing fixya
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged. or may
be bad and needs to be replaced.
Also if the cycle timer is going out this may cause the drain to continue so i would havethat checked out as well ok?
Hope this helps
Best regards Mike
Aug 04, 2011 | Danby DDW497W Portable Dishwasher
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Mdb7100awb won't drain. Water remains in the bottom of wash compartment
This dishwasher has a auxiliary drain motor on the right hand side. This motor often will get clogged with debris. Pull the unit out and check the drain motor for debris. The pump has three small screws that hold it in place.
Apr 22, 2011 | Maytag MDB7100AWB Dishwasher
WASHING MACHINE SHOWING ERRORMESSAGE 5E
rw
Hello, and sorry to read about you 5E code issue.
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose. A good indication that the drain hose is kinked is excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
If your hose shows no kink's you may have a clogged pump.
I have tried to help you. PLEASE rate/vote the response. we take the time to respond to you. take the time to rate. Thanks and good luck on your problem.
Dec 24, 2010 | Samsung WF306BHW High Efficiency Front...
Water staying in machine after wash completed
Hello. Generally, the problem is debris in the drain pump or in the drain line which goes from the base of the machine up into the drain under the kitchen sink. Begin by removing the lower panel on the front of the dishwasher and disassembling the drain line there. Be prepared for about 3 cups of water. Then REmove the pump and visually examine it on the inside. If you don't find the debris there check the entire drain tube, and the connection area under the sink. J.
Jul 28, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher is draining during the wash cycle, but leaves water in the bottom at the end of the wash. What could be the problem?
Hello Ellsaesser,
Dishwashers typically leave water in the drain system exitting the pan but not a lot of water. If yours does then make sure you clean the drain screen ( normally located in or around the drain tube exitting the pan of the dishwasher..) If after cleaning that and after a normal wash cycle you continue to have significant volumes of water in the pan, the pump, lines leading to and from that pump may be restricting flow or damaged.. Those are a few of the normal culprets for why there is a lot of water in the pan of dishwashers after a cycle.. Hope that helps you identify the problem and resolve it,..,
Regards
Nov 29, 2009 | Frigidaire Dishwashers
DIshwasher doesn't drain or fill
Hello annie8866,
First off.. unplug power and then reapply power to it for a little while to see if a power reset will put it back in the proper sequence.. next, check inside the base for a drain inlet and a filter/screen and clean anything you see out of it.. Then try cycling it without dishes to see if it will run thru a cycle and drain properly.. Its ok to add a cup or two of white vinegar during the wash process to remove byproducts of the wash from the inner components.. Make sure the drain hose is not clogged or kinked up.. Try these things and get back to me if it is still misbehaving..
Sep 29, 2008 | Magic Chef CDB6100 Built-in Dishwasher
Pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Feb 03, 2008 | Haier HDP18PA Stainless Steel...
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
