Question about Hitachi StarBoard FX-77
WERE CAN I FIND THE SERIAL NUMBER FOR STARBOARD?
I WISH IF YOU CAN HELP ME I DO HAVE StarBoard Software 8.1 BUT I WANT TO UPGRADE MY VERSION ,,THEY REQUEST THE SERIAL NUMBER BUT I DO NOT KNOW HOW TO GET IT CAN YOU HELP ME THANKS
4 Suggested Answers
SOURCE: notepad 'floating' in the way
On the mac, it was an interaction with the 'Inkwell' handwriting recognition software. I turned that off in System Pref's. It may have actually only been the check box 'in any application' rather than completely off.
So Starboard works great now!
thanks
Posted on Aug 19, 2008
bob_computer
  • 3153 Answers
SOURCE: The starboard does not connect to the computer
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Posted on Sep 18, 2009
SOURCE: StarBoard Fx-77 Pen does not write on the boards surface
i dont know why i bother looking on here, ive looked for a number of solutions for different problems and there is never any answers on here
Posted on Dec 03, 2009
Cant find my serial number
You will find it engraved into the external transom, just above the water line on the starboard (right) side. This is where the Coastguard look.
Another location is the makers serial and this is generally inside the front anchor locker.
Mar 04, 2016 | Boating
I lost my starboard software cd
Software Download
Need to upgrade your software, or maybe you have misplaced your original disk. Click here and follow the procedure to request a downloadable version. You will need to have the serial number(s) of your product(s) to hand.
Software Download
Nov 04, 2014 | Hitachi StarBoard FX-77
Were can I find serial no on 9.9hp mariner
Hi!
Your serial number is located on the lower starboard side of the engine block. A serial number is also located on the starboard side of the swivel bracket.
Here's a link to your service manual if you need it.
Hope this helps.
-Steve
Boatinfo Mercury Service Manual for 9 9 15 hp
Sep 04, 2014 | Boating
383 mag stroker serial number location
You'll find the plate at the Starboard or Portside of the engine, near the flywheel plate.
Usually there is also a sticker on the flame arrestor cover.
Jul 23, 2013 | Mercury Marine 6.3L - 383 Engine Package -...
Turns hard to starboard when in auto
Verify that it is configured for your installation. Some units can be installed either on the port or starboard side, and they have to be programmed accordingly. Verify this in the user's manual.
Jul 04, 2013 | Raymarine St8002 Smartpilot Autopilot...
Windows 7 does not recognize Hitachi Starboard t-17sxl
Using the T-17sxlg on Windows 7 now. Did you ugrade the software to 9.33?
Jun 09, 2011 | Hitachi STARBOARD T-17SXL
Where do i find the serial number on my fx duo board
Take your cell phone and put it on it's camera setting. Then go to your Starboard and take a picture of the lower left of your Starboard (on the corner--facing the floor). That is where you will find the serial number. Look at the picture--there it is-the serial number!
Sep 09, 2010 | Hitachi StarBoard FX-77
How to connect a 2 bank (4 batteries) to the 3 GUEST switches.
Sorry for the delay. I don't understand why they have the third "on/off" switch. Normally on a boat like yours, the set would be as follows :
Each pair of batteries would be jumped together to make a single large bank. We can then consider them "bank 1" and "bank 2" usually they will correspond to port and starboard.
Now you will take the positive lead from bank 1 and connect it to B1 on the port switch and then jumper it to B1 on the starboard switch.
You will do the same for bank 2 and the starboard switch.
The "common" on each switch will be your positive output to the motors corresponding them to port and starboard.
Now you can run your port motor with the port switch selected to battery 1 and the starboard motor with the starboard switch selected to battery 2.
Your emergency parallel is already built in. If battery bank 1 dies, you can start both engines with battery bank 2 and vice versa. Putting the switche(s) to the "all" position will allow you to start/run the engine(s) form both banks at once.
You can use the third switch to supply the "house" system. Take its power feed from the "common" terminal on either of the battery switches. In this way you can isolate which battery bank you use to draw power from for all of your accessories so there is no fear of you running a battery bank dead and being stranded. For example if your house feed is connected to the port battery switch and you have the port battery switch selected to bank 1 (port bank), should you run the battery dead listening to the radio you can simply start the starboard engine and then select "all" on the port switch. Now the starboard engine will be charging the port battery bank, bringing the house system back to life and allowing you to start the port engine.
In order for the system to work it is important that all of the battery and engine grounds be connected together in a central point (a common buss bar).
Dont forget that you cannot switch battery switches while the engines are running.
Good Luck!
Jul 22, 2009 | Guest 297 Secondary Station Control For...
Notepad 'floating' in the way
thanks
Aug 19, 2008 | Hitachi STARBOARD BT-1 FREEDOM TABLET...
Oct 18, 2007 | Hitachi StarBoard FX-77
Hitachi StarBoard FX-77 Logo
83 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
