Question about HP Deskjet 3512 Inkjet Multifunction Printer/Copier/Scanner
Hp deskjet 3512 scan more than one page - HP Deskjet 3512 Inkjet Multifunction Printer/Copier/Scanner
SOURCE: HP deskjet f2280 won't scan
you can try clicking MY COMPUTER then C: then PROGRAM FILES then Hp then Destination folder then bin then find the hpscnapp with a printer icon.Scan will work.Hp 2280 frequently encounters error especially if you're using VISTA. Hope i helped! Good day!
Posted on Aug 05, 2009
Hamedo
  • 57 Answers
SOURCE: hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
Posted on Nov 19, 2008
  • 788 Answers
SOURCE: hp deskjet f4180 prints test
I have reviewed your problem and have the fallowing suggestions.
Lift the cover and press copy or scan manually. ( Unit must be connected to your computer. )
You will see a long gear that the filament rides on. ( Back and forth ).
If the lamp comes on but does not move, you will need to remove the cover and set it back in place.
If the unit rides up and down but has no lamp, you will need to have serviced or replace the lamp.
Hope this information has helped you..
Please rate......
Posted on Oct 16, 2009
  • 54 Answers
SOURCE: hp deskjet f4280 will scan but only shows the document as black
There is a hardware issue and the printer needs to be serviced
Posted on Nov 07, 2009
Riztech
  • 731 Answers
SOURCE: how to scan a page
Please click here and find the ways to scan using the printer.
Regards
Riztech.
Posted on Dec 30, 2010
I can't install my cartridge in my Deskjet 3512.
Turn the printer on.
Load paper into the paper input tray.
Open the cartridge door (located on the front of the printer), look for the recessed area, grab the built in handle (part of the recessed area) and pull forward.
Once the door is open, the cartridges will automatically move to the center position.
To change a cartridge, pull the top, front of the cartridge down, it will move to a 45 deg position. Then just pull out.
Open the new cartridge box, take the cartridge out of the wrapper, pull the tab to remove the tape covering the electrical contacts, (make certain you don't touch the contacts or ink nozzles), install the new cartridge (color on left, black on right), slide it into the holder and press up on the top, back until it latches into place. Then close the door.
The printer will print a test page. Once printed, take the alignment page it printed and put on the scanner glass (corner to top, right, see the guide printed there). Close the scanner lid and press the OK on the control panel. the printer will now align the print heads based on the page it printed. Once done, press OK again. Done.
Oct 20, 2014 | HP Office Equipment & Supplies
How do I scan multiple pages on an HP Deskjet 1055 and make it one large file? or upload several pages to this site?
If you use HP Software to operate the scanning from the deskjet then you can set the scan settings to compile a number of document pages into one file.
Best to download the full set of software for your printer from this site and let it install. Sometimes older version may not have the new features you need.
HP Deskjet 1051A All in One Printer Drivers
Aug 08, 2014 | HP Deskjet 1055 All-in-one - Multifunction...
How print sideways hp 3512 ?
If you are using annotative text, it may be one of the settings with your text style. Type STYLE and select the style that you are using.
There is a check box for annotative text (it shoudl be checked) and directly under it is another one that aligns or rotate the text with the viewport. Uncheck this option. otherwise reinstall the driver. HP Deskjet 3512 Printer Driver Download For Windows 78 1XP
Jul 21, 2014 | HP Deskjet 3512 Inkjet Multifunction...
Cannot detect allignment page
cannot detect alignment page- two possibilities-
1: hen the printer prints the alignment you can physically see the lines and colour shades being printed onto the sheet- this should then be scanned with the electronic eye built onto the carriage assembly- usually one automatic operation- if you can see a good clear image printed ( blocks/lines.boxes) and the printer cannot see the image it stands to reason the electronic eve ( spectrophotometer) is not reading the image correctly or at all, if however there are 'missing' areas of the calibration print then the problem lies with the printing side and I would recommend cleaning/ replacing the printheads as required
Mar 16, 2014 | HP Deskjet 3512 Inkjet Multifunction...
Can not get the wifi working
the wifi board might be faulty on the printer or check the router. if a laptop can connect to the router then it is the printer that is faulty. send the printer to a service partner of HP so that a technician can have a look at the wifi board.
Nov 12, 2013 | HP Deskjet 3512 Inkjet Multifunction...
My hp deskjet 3512 will not connect with the router and cannot print
check to see if any other device can connect with the printer if they can then the wifi card on the unit is faulty and needs to be replaced.
Nov 05, 2013 | HP Deskjet 3512 USB 2.0/Wireless-N...
HP Deskjet 3512 Inkjet Multifunction Printer/Copier/Scanner Logo
169 people viewed this question
Seeker5211
Seeker5211
