Question about Craftsman Garden
Problems with craftsman 18hp ohv
Tractor wont move and when I try to put in gear the mower stalls out
  • Craftsman Master
  • 2,239 Answers
If the engine stalls as you pull away there are two possibilites, either a micro switch is defective ( probably the seat switch, or a poor connection on the block connecter ) or the brake on the side of the gearbox is stuck on ( this is a disc on the side of the gearbox and should be sdjustable )
Posted on Dec 08, 2012
panilling9
  • 284 Answers
SOURCE: Looking for manual for Craftsman 917.256552 15HP
if you go to sears.com click on parts direct
enter your mod # and to the right of the next page says get manual click on that and then click on view manual and it should come up for your mower
Posted on Jun 09, 2009
  • 61 Answers
SOURCE: The new battery on my Craftsman LT1000 18hp riding mower will not charge. Anyone have any ideas?
ck for blown fuse, ck for broken wire.
Posted on Sep 06, 2009
  • 1114 Answers
SOURCE: lawn tractor won't move when put into gear
First, check the tension of the drive belt. There should be an idler pulley which is spring loaded that creates the tension. When you push the clutch in, it will release the tension. Also, check to see if the rear wheel hubs have set screws which lock them onto the axle Make sure they are tight.
Posted on Aug 02, 2009
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
Posted on Jun 01, 2010
  • 146 Answers
SOURCE: starter gear doesn't move up to engage flywheel gear when started
The solenoid does two things -- it closes an electrical contact to run the starter motor, and also pulls a lever to slide the motor gear up to engage the flywheel. Since the contact is closing, the solenoid itself must be OK, but the lever could be broken, or the sliding gear could be binding or stripped. Since you're looking at a probable replacement, try cleaning with compressed air, then squirting some WD-40 into the starter gear area - you could get lucky! Otherwise, you can replace the starter/solenoid assembly -- you can find replacements on eBay for about $80. Less expensive but more time consuming is to remove the assembly, disassemble, and replace just the defective parts if you can find them. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 15, 2010
Engine stalls when I put it in gear and let out the clutch
Check your drive belt then check and see if the mower moves the rear could be bad
May 03, 2015 | Garden
I have a RX75 when put in gear it wont move Why?
something broke in transmission
Sep 17, 2014 | Garden
How do i unlock brake tried resetting arms stalls when engaging handles also wont come out of gear when releasing bypass valve
you most likely have a module behind your battery... it's either bad or corrosion has taken it's toll and you will also need a wire harness ... and yes, when those go bad, you can't even move those things...
Sep 03, 2014 | Toro Mowers - Time Cutter SS4235 42""...
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
Wont move when backing up
Hi. It would be best to know the manufactures model of your tractor or the transmission model number to best help. Typically issues with riding mower transmissions is in the shift keys inside the transmission. I would also ask if the transmission gear is moving far enough to actually put the transmission in reverse. Be sure nothing is binding or that the shift arm is not bent. That is the first thing to try. With more information I may be of more assistance.
Nov 28, 2013 | Craftsman Garden
Stalls when put in gear
Replace the seat micro switch. Also make sure the block connector is fully pushed home on the micro switch.
Jul 16, 2013 | Craftsman Garden
Craftsman lt1000 wont start because of gear shifter
go to sears parts direct enter model # it will show u every thing if u have a printer u can print a full manual
Mar 05, 2013 | Craftsman Garden
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman Kolhler 18hp gas in oil and misfiring
It sounds like you have either a stuck float in the carb or the float needle and seat are worn out.
May 20, 2012 | Craftsman Garden
Garden Logo
77 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
