Question about InFocus Work Big IN24 DLP Projector
InFocus IN24, Dark Spot in center of Image, Plastic Prism Behind Lens for an InFocus IN24
Noticed that several members have asked the question but no clear cut answer was ever given.. I purchased a used InFocus IN24 for relatively little money from a garage sale.. The previous owner gave up trying to fix it.. Complaint: Large Dark Shaded are in center of image.. Since no warranty and little investment thus far; I decided to dive into to it. Found the problem to be the Plastic Prism behind the lens.. It has a "caked on" burnt spot in the center of the prism.. Now here is my problem.. No Part number and InFocus Tech Line was of no help.. They directed me to EDexdeals.com and that was a dead end as well. Does anyone out there know the exact name to this part or better yet, know the part number to this item that I have described? Any and all help would be greatly appreciated... Thanks...
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: Tranlucent dark spot on Optoma image. Looks like
is it an optoma or an infocus? if it is the infocus, it needs to be replaced. however, to replace it, you need to remove the entire optical engine. now off of that, remove the clorwheel and clip, the main board, and the tunnel (on this model it is called an integrator rod) assembly. to get that out, remove the 3 tap screws and the large screw. once you can slide it out, remove the foil from the front, slide out the inside tunnel assembly, remove the clip, then the tunnel. because the clip is an exact fit, you cannot have anything on the tunnel that increases the size. reverse the instructions to reassemble (but you will need to replace the foil with a new one). warning: you now need to realign the tunnel using 2 of the tap screws. if you have not done this before, it is very difficult and dangerous, as you need to have the projector powered on and the screws are way inside next to the power supply. there is a risk of electrocution and damage to the projector. best bet- send it in to an authorized infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Dec 01, 2009
SOURCE: Infocus IN24 Projector has large Dark Grey/Black
There is a lens(looks like a small magnifying glass) made out of plastic that the light shines through to focus the light on the mirror before it hits the DLP chip, that lens is Melted in the center. I unfortunately had the same thing happen to me, and I am unable to find a replacement part.
Posted on Feb 18, 2011
Dark spot in middle
A plastic prism between the lens and the lamp is melted. can't find part no. PLNS-A056WJN2
Jun 30, 2013 | Sharp XR-10X Multimedia Projector
InFocus X3 plastic lens
If you still have the owners manual there should be an 800 number or some sort of customer support for it. Unless it's really old that is your best bet for the internal pieces
Nov 23, 2012 | InFocus X3 DLP Projector
Where could I get the plastic lens for my infocus 61md10
Remove the little plastic lens and throw it away. There is no replacement available anyway. Reassemble the tv and it should work fine. Mine has been good for quite a while now.
Dec 08, 2011 | InFocus ScreenPlay 61" Rear Projection...
Dark spot center of picture
THis could be caused by a burnt LCD immager or a large spec of fluff.
Jan 29, 2011 | InFocus IN24 Multimedia Projector
I too have this problem with my projector infocus IN24, and it has slowly grown to extend almost all of the way up the center of the screen. I have reseated the bulb assembly laer change the lamp, and...
If you are experiencing a colured blob, usually lack of blue producing yellowy stain. The cause is excess heat on the blue LCD panel. This is a replacement job on the panel as it won't recover.
Keeping the air ways clean and filters clean will help to stop the growth.
Hope this helps.
Jan 19, 2011 | InFocus IN24 Projector
Infocus IN24 Projector has large Dark Grey/Black Spot in the middle of the image.Lamp has 600 hours,Installed my spare "NEW" Lamp,still the same,Bulb makes no difference.Was watching a movie...
Jan 16, 2011 | InFocus Work Big IN24 DLP Projector
My projector has little white dots that appear on a black or dark background, I've replaced the bulb and still have the same issue.I've read someone say the something about cleaning the light engine, is...
Take off the front bezel, then remove the screws from the lens,pull the lens out and blow it out with compressed air. Do not touch the mirror or magnifier inside. If this doesn't get all of the blemishes, then you will have to remove the top cover and then the top silver part of the engine and blow it out from the top.
Apr 26, 2010 | InFocus IN24 Multimedia Projector
Screen goes blank and projector shuts downafter about 10 minutes (IN24 In Focus projector)
ballast/ power supply issue. you'll need to send it in to an infocus service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 28, 2009 | InFocus IN24 Multimedia Projector
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
Nov 15, 2009 | InFocus LP70+ Multimedia Projector
Dark spot issue.
Its an acrylic condensing lens inside the light engine that has melted/warped. You have to pullout the entire light engine then disassemble the optical light tunnel to get too the lens. Then you need a lens-smith to cut a new lens because Infocus won't stand behind this design flaw. Its really a shame on Infocus!
If you need more info contact us here: click here
Sep 19, 2009 | InFocus ScreenPlay 61" Rear Projection...
InFocus Work Big IN24 DLP Projector Logo
89 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
