Question about MA Audio HK598 Car Audio Amplifier
I need an Instlation Manual for a ma audio HK-598
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: my ma audio hk 4000
If there is no protection light on, be sure the input is on. Some head units need to be turned on manually (factory set to OFF).
Verify the subwoofers are wired properly.
A list of your components would help to solve your problem.
If it is new, it should still be under warranty - worst case scenario output transistor(s) blown, or power supply bad.
Posted on Jan 09, 2009
etirbynnor
  • 655 Answers
SOURCE: my ma audio hk 898 will power on but will not push
Hello 76firebirdfo,
If there's no sound at all from the subs and you know they are good, there's probably no output from the amp. It's either wired incorrectly or it is defective.
If there's some sound but just not loud enough, then either the amp is not getting enough of an input signal from your head unit, or the amp settings are not adjusted properly. Adjust the crossover and gains for the best output to subs. LP filter on, crossover frequency at about 80-100Hz, and gain to maximum without distortion when head unit volume is at about 3/4 maximum.
Hope this helps.
Posted on Jul 14, 2009
  • 102 Answers
SOURCE: how do i drop it down to 0.5 ohm
there are no settings on the amp, if it is made to be stable at .5 ohm you will need 8 voice coils to make .5 ohm, if your subs ar 2 ohm, you will need 4 coils to make .5 ohm when hooked in parallel
Posted on Sep 23, 2009
jcameo7270
  • 675 Answers
SOURCE: i have a ma audio
Disconnect the speakers and then try it again...there may be a shorted speaker or wire if the amp comes out of protect after you disconnect the wires...if the amp stays in protect after you disconnect the wires then there is a problem inside the amp with the circuitry and it will need to get serviced by an electronic tech
Posted on Jan 23, 2011
I have 2 MA Audio HK 15 X 2 subs and voice coils are blown. How do I fix them
There is little chance that you can do anything about it. The exact voice coil would have to be identified, the old ones taken out, and replacing them is technically difficult/impossible without the proper tools and experience.
Apr 13, 2016 | MA Audio Car Audio & Video
I have a ma audio hk-602sx and my protect light wont go off and somthing is clicking inside and as it clicks the protect light blinks.
Jan 23, 2011 | MA Audio HK602SX Car Audio Amplifier
I have the older HK 4400 Chrome with two needles only one side is working
Open the unit and inspect for a bad or cold solder connection on the side in question. You can compare the circuit trace with the other that is working to verify the connections.
Nov 24, 2010 | MA Audio HK4000D Car Audio Amplifier
My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
MA audio HK 12 competetion subwoofer, the 1500 rms one, what is the ''Fs'' on that thing? There website doesn't tell me. Any guesses if you can't find the answer?
Fs is a thiele-small parameter, meaning resonance. You can use these parameters to simulate the woofer's bass response in different boxes etc.
http://en.wikipedia.org/wiki/Thiele/Small
Jan 21, 2010 | MA Audio HK12X2 Car Subwoofer
How do i drop it down to 0.5 ohm
Sep 23, 2009 | MA Audio HK401SX Car Audio Amplifier
My ma audio hk 898 will power on but will not push subs at all what can i do
Hello 76firebirdfo,
Hope this helps.
Jul 14, 2009 | MA Audio Hard Kore HK-898 Car Audio...
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
My ma audio hk 4000 amp is powered on no sound coming thru subs amps brand new
MA Audio EHO152's
My honest opinion is that MA Audio is not in the same category as the other subs you mentioned. I buy a lot of electronics on ebay to avoid the giant mark up from stores. I found some MA's and got them for $.01 because no one wants them. However - any sub can preform well if you put the in the right box. I am a technician, not a salesman so you just heard my opinion for an experience standpoint.
Dec 22, 2007 | MA Audio EHO152 15" 5000 Watts Subwoofer...
MA Audio HK598 Car Audio Amplifier Logo
94 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
