Question about Mercedes-Benz Vehicle Parts & Accessories
Purpose of idle valve - Mercedes-Benz Vehicle Parts & Accessories
  • Mercedes-Benz Master
  • 14,405 Answers
To control the idle.
Posted on Dec 07, 2012
What is the purpose of the IAT? 2006 jeep grand cherokee laredo
Do you mean IAC. This is the Idle Air Control Valve and would be what you need to replace.
The Idle Air Control (IAC) valve is an electric actuator controlled by the engine computer, which regulates the engine's idle speed. A faulty IAC valve will make the engine idle rough and possibly stall.
Dec 31, 2014 | Jeep Cars & Trucks
Low idle
You might try cleaning the air intake especially the backside of the butterfly valve. with choke cleaner or a special cleaner made for that purpose. Remove the hose between the air filter body and the air intake. Open the butterfly valve and spray both sides of the valve as well as the sides of the intake. If that doesn't work you'll have to dig deeper. You'll probably need to monitor sensor in that case.
Mar 28, 2014 | 2001 Ford Escape
A smith gs 100 302 Cranks and runs full throttle with air valve open. But if you close the air valve, the motor shuts off
think it has a air cut off valve have a look for that. if it cuts air it will not idle. its used for cutting the engine.
Feb 18, 2018 | AO Smith Cars & Trucks
I have a mazda 626 2001 every time that I put the car in reverse our drive to cut out
IAC (idle air control valve) the purpose of this device is to maintain a target idle,and adjust for engine load condition
Mar 23, 2012 | 2001 Mazda 626
Idle air control valve
Any auto supply store will sell cleaners in spray cans for that purpose, also clean electrical contacts with electrical cleaner for that purpose, good luck
Feb 17, 2012 | 1999 Ford Escort
Car dies on decel no codes
Hi!
It would help to have the model, year and engine since different years use different sensors and output actuators. With no codes present, i would look at the IAC valve (idle air control) assuming your model has one. This valve serves two purposes. One is to control the idle, and the second is to act as whats known a dashpot on older vehicles. It keeps the idle slightly higher so the vehicle doesn't stall when decelerating.
The valve is located near the throttle body and is controlled by the vehicles computer. It's usually easy to install and normally fastened by two screws. The part cost could be from $40 - $200, again depending on the model.
The only surefire way to diagnose this would be to install a scan tool and monitor sensors and the IAC duty cycle commanded by the computer. Good luck, if you want to add some more info I may be able to help a bit more.
Apr 15, 2011 | Ford Freestyle Cars & Trucks
Need to adjust my idle how do i do that
air idle control valve, I dont belive you have a ideler set screw..I do belive the problem is what I have Listed..........Best of luck
How can I tell if I need a new air idle control valve?
If your car has a rough idle or the idle cycles up and down, then chances are that you have a bad idle control valve. On modern vehicles, the purpose of the idle air control valve is to regulate your idle, and keep the idle smooth. The idle valve is controlled by the ECU or the computer, and when in gear the idle should be between 800 and 1000 rpm, and not in gear, between 700 and 900 rpm
Dec 02, 2010 | 1999 Oldsmobile Alero
My 2003 gmc denali will not idle. It runs great on the road.
most likely a bad idle air control valve. Its only purpose to to adjust the idle for loads like the AC and turning the power steering..
Jul 05, 2010 | 2003 GMC Yukon Denali
1996 Honda Accord Rough Idle Even After tune up performed Changed spark plugs, distributor cap and rotor wheel along with all spark plug wires, changed fuel filter, air filter, spent $150 on fuel injector...
Perform a valve clearance inspection and adjust if necessary. Tight or sticking valves will cause a misfire or rough running concern. Note: Perform valve adjustment when the engine is stone cold. 4cyl: INT 0.26mm EXH: 0.30mm (V6 engine are hydraulic and no adjust necessary.) Also check for a sticking or stuck open EGR valve. For diagnostic purposes only: Remove the EGR valve. Place a business card over the EGR passage and bolt the EGR valve back on. This plugs the EGR ports and if the misfire goes away the EGR valve is partially stuck open and is defective.
Check for low fuel pressure. Check for low compression. Check cam timing. Check for a weak ignition coil. Also don't over look the possibility of worn or broken engine mounts which cause excessive engine movement and engine vibration. -hope this helps
Mar 02, 2010 | 1996 Honda Accord
It feels like it is going to stall. I changed the
Are you having any check engine light on?If yes you may need a diagnostic.Else clean or check your idle speed controller..
Nov 05, 2009 | 2004 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
