Question about Kenmore Washing Machines
How do I get the top open on my 80 series kenmore washer
Loose switch
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 07, 2012
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Nov 02, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 Series washer
If you're talking about the lid switch, here's the instructions you need:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in on the side of the tub opening and a ground wire attached to the casing. Remove the connector plug, by pushing in on the release tabs on either side and pushing it down through the opening in the washer casing. The wire harness will be held in place by clips under the washer rim. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Good Luck and I hope this helps you.
Posted on May 07, 2008
Maytag317
  • 1136 Answers
SOURCE: replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 03, 2009
JULIANFIX
  • 975 Answers
SOURCE: How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Posted on Oct 26, 2009
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
Clicking noise. BUT DRAINS FINE!
kenore don't have belts they have couplers,check the lid switch-mike
Jul 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80 will aitiate but not spin with load
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Jul 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer will not stop filling up
one of three things,inlet water valve bad,water level hose came loose or water level switch is bad,check all tree and let me know-mike
Apr 14, 2009 | Kenmore 24902 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
I replaced the lidswitch on a Kenmore 80 series washer. Nothing
Possible bad pressure switch. Turn unit on and jump out 2 wires at a time (3 wires go to it). See if any of your combinations get unit running (one of them will cause water valve to open); if so then that is your problem. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series
sounds like your control switch needs replacing.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
12 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
