Question about Maytag Dryers
Maytag model # LDG9804AAE makes a banging noise when running, was wondering if it could be an old belt or rollers or what?
    New Friend:
    Problem Solver:
  • 7 Answers
Sounds like a bad belt tensioner.
Posted on Dec 07, 2012
  • 85 Answers
SOURCE: While my dryer is running it makes intermittent squeaks.
most of the time your rollers and belt are fine 1st thing to check would be the idler pully which keeps the tension on the belt so the tub spins
Posted on Dec 19, 2008
SOURCE: my maytag electric dryer model
maytag dependable care quiet plus h.d. intelidry control makeing nois when starting then it stops makeing nois works ok
Posted on Jan 17, 2009
SOURCE: Dryer -New belt & drum rollers & still banging - Maytag
check the motor, it could have bad bearings
Posted on Jun 17, 2009
  • 126 Answers
SOURCE: loud banging noise in dryer (maytag)
the most common culprit of banging is an uneven spot on one of rollers. It may not be really noticable, but a slight flat spot can form on them.
Posted on Nov 15, 2009
hunter19_46m
  • 7482 Answers
SOURCE: maytag dryer makes banging noise when running
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on May 25, 2010
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
Mar 07, 2010 | LG DLG5988 Gas Dryer
Loud banging noise in dryer (maytag). Have taken dryer apart. don't know how to tell if drum rollers, belt, and blower wheel are okay. Don't know what else could be causing loud noice.
Nov 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag dryer is 14 years old. Now it makes a
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Yes, replacing the drum rollers is fairly cheap especially if you do it yourself, saves you the price of a new dryer for a few more years maybe.
Good Luck,
I hope this helps
Oct 08, 2009 | Maytag Dryers
My dryer just started making a slight banging noise when it runs
Does it bang all the time or just ar start up?
All the time ... maybe you left a sneaker inside :-)
At start up ... normal noise. The belt has to do some fancy curlie cue stuff at the bottom and it takes a while for it to get stretched back to normal just like you do when you are abruptly awakened (when someone presses your START button) :-)
Let me know if this helps
a
Sep 21, 2009 | Dryers
Jun 17, 2009 | Maytag Dryers
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Maytag gas Dryer is Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 19, 2009 | Maytag MDG7600AW Gas Dryer
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
69 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
