Question about Hotpoint HSS25GFP Side by Side Refrigerator
I have a hotpoint refrigerator serial# hss25gpfjww refrigrator side quit working took the back off and found that the coil coiling fan was burned up compressor was hot to touch replaced the fan and plugged it back in and it only clicks on and off at the circuit board compressor will not kick on
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
You will need to replace the main control board on the back of the unit. Here is the part to order.
Posted on Dec 08, 2012
  • 17 Answers
SOURCE: hotpoint side by side csx22grbk serial vz247504
chances are you have a faulty module (board) sounds like you'll have to call an engineer oput to replace it
Posted on Dec 10, 2007
  • 492 Answers
SOURCE: Hotpiont side/side HSS251FMB not cooling
Compressor might be working but you may have lost some freon. Continued operation with low freon can lead to other problems. This may require a service call since recharging freon can only be done by a service professional.
Posted on Apr 30, 2009
  • 103 Answers
SOURCE: HSS25IFMD quit cooling--was plugged with dust/dirt
Hi: When both sides get warm it is a bad sign. I wish I had better news. Hope all works out for you, Jeff
Posted on May 31, 2009
  • 104 Answers
SOURCE: Refrigerator compressor overheating
Seems as if you have arefrigerant leak (or water vapor in the system) - both of which will trash the compressor in short order.
Time to take it to a pro who will put gauges on it and find out.
Posted on Sep 22, 2009
  • 71 Answers
SOURCE: Need to replace a clicking circuit board
yes just take out the 1/4 inch screws from the plate on the back of the fridge and unclip the board. There will be quite a few plugs but no worries cause they will only plug into the ports they will made for so you don't need to worry about plugging the wrong wire in anywhere.
Posted on Oct 03, 2009
Testimonial: "Thanks for the help, I have the circuit board off. Dave"
My Hotpoint side by side refrigerator wont keep cold but the freezer is working fine. I unplugged it and felt the compressor it was hot. The fan and coil was covered in dust. I cleaned it off and wasn't...
There is only the coil in the freezer and a fan moves the air to the refrigerator. Check the fan inside the unit. IT might also be icing on the coil that is causing no air flow.
Aug 19, 2014 | Refrigerators
Hotpoint FFA60 - Freezer Fan not working
It sounds as if the fan motor itself has failed, & without the fan, only the coils will get cold. A replacement can be obtained from any appliance parts store, or from Hotpoint...check the website. If you are not experienced in appliance repair, I suggest you call a repair person , as some of the fans can be difficult to replace, & it is easy to cause additional damage.
Jul 06, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Is there a reset button on a hot point side by side refrigerator?
Look how to repair Most of GE and Hotpoint Refrigerators. Here I replaced Evap Fan Motor, Defrost limit switch and computer board. Very often by looking at computer board u visually can see if its burned out, sometimes from back side of it one of the relay contacts burning out.
Jul 24, 2014 | GE Hot Point - HTH18GBCCC Refrigeration :...
I have a 6-2003 Frigidaire side by side Model#FRS23F4CW0 Electrolux refrigerator. It gets hot in the middle of both doors the frame only. Is that normal.
Mine did the same thing and then stopped cooling within a few weeks. I opened up the lower back cover to check the coils for dust and found that the fan had stopped working. I took a box fan and blew air through the coils and it started working just fine. Now I just need to fix the fan problem and I'm back in business. Bottom line: check under the fridge to make sure the coils are able to dissipate the heat.
Mar 09, 2010 | Frigidaire FRS23F4C Side by Side...
Not cooling
Roy,
Are the evaporator coils in the freezer frozen up?
The evaporator is located behind the cover in the back of the freezer.
If so this may be a defrost issue.
The adaptive defrost timer may have failed.
This is located in the ref. side inside the front control pannel.
If not then you may have a freon leak.
This would have to be repaired by a qualified technician.
Jan 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have hss25gfp side by side the freezer stopped freezing and it very hot on the middle divider. I took off the bottom on the back and it was caked with a bunch of lint. I cleaned it off. But noticed the...
If the compressor is running the condenser fan should be too. If the fan does not run the compressor will overheat and stop. If you cool the underside with a small box fan and the chill returns to the box, replace the condenser fan.
May 29, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator evaporator fan won't run but compressor working
is the evaporator coil frozzen you may have a defrost problem
Mar 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigerator
Try pulling toe plate at bottom front and clean the condenser coils. If they are plugged, it will cause this to get hot. If you can't see coils in front remove back panel and clean coils there.. Give it time after cleaning to see if it helped. If no change, remove back panel and check to see if fan is turning when the compressor is on.
Also check for something caught in fan blade, such as a dead mouse or a dead coupon. If fan isn't turning, may need condenser fan motor. If still need help, give us a model number. Found in refrigerator compartment at top on side walls.
Nov 22, 2007 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
53 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
