Question about Canon ImageCLASS D1120 All-In-One Laser Printer
Canon image class D1120 not working
The machine is on but shows no display and will not print or scan
IB4G2008
  • 3587 Answers
SOURCE: Canon Image Class MFC 8180c "Download Stanby"
that's not too good...let's get down to cases here
Posted on Mar 04, 2008
  • 628 Answers
SOURCE: canon copier image class D760 / system error E0003
Try this one from Canon:
Issue: ERROR LCD: System Error E003
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Posted on Dec 10, 2008
  • 100 Answers
SOURCE: printer doesn't put image on paper
The laser shutter is bad or stuck. The new one is redesigned. The shutter could be removed but that would break saftey laws. If its under warranty still have a repair center do it.
Posted on Jun 25, 2009
  • 92 Answers
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
wayneard
  • 1901 Answers
SOURCE: i am using the canon image class mf6500 and i
Go to:
Canon MF6500 Series Support
If the Drivers & Downloads tab is not selected, click on it.
Although it shows a MF6550 at the top, the software and manuals are for the 6500 series of printers. There are guides for printing and scanning further down the list you can download too.
You do not say what operating system you have, but there are only drivers for Vista and Mac OS.
Thanks for using Fixya.
Posted on Nov 05, 2009
How to fix u052?
Error U052 = Please check that print head contact pins of the carriage are not bent.
Or else you may need to replace
- Print head
- Carriage Unit
Jun 29, 2014 | Canon MG5150 AllInOne Printer
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
The device will not copy or scan. The display says check document but there isn't a document in the device
Try to reset the machine by unplugging the computer cable in the back of the D1120, wait about 30 seconds and plug in again. Should reset the system.
Sometimes when it keep saying jam, I remove the toner cartridge and then put back in. That works also to reset the system.
This is really a great machine with it's little querks, but for the most part, we get along pretty well..... hope this helps. :-)
Leslie
May 19, 2014 | Canon ImageCLASS D1120 All-In-One Laser...
ADF will not feed
Canon Image class does not feed.
Dec 29, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Scanner not woking
If you can make copies but you cannot scan documents to folder or email then I would consult your resident IT person. If you are not able to make copies but the machine prints then you have a bad scan lamp. If you are not able to make copies or print and the scan lamp is as bright as can be then your laser unit is shot.
CANON IMAGE CLASS SUPPLIES
Sep 12, 2012 | Canon imageCLASS D1120 Copier
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
My printer canon 4412 not work the display showing on main switch e202-0002
hi my printer canon mf 4412 printer is not working it is showing error batten red light showing , display is not showing pls solve problem pls it is urgent
Apr 05, 2011 | Office Equipment & Supplies
D1120 IMAGE CLASS CONTINUOUS PAPER JAMS ALTHOUGH NO PAER ACTUALLY JAMMED. APPEARS THAT PAPPER IN PAPER TRAY IS NOT FEEDING OR CATCHING UP TO BE COPIED.
first of all try to clean trays picked up rollers and also look for a piece op paper or something else in internal paper path
pifonski
Feb 20, 2011 | Canon imageCLASS D1120 Copier
Canon ImageCLASS D1120 All-In-One Laser Printer Logo
48 people viewed this question
old marine
old marine
