Question about Toshiba e-Studio 232 Black and White Copier
Radf problems on e-studio 232
Hello. When i start copying from the radf the first copy it's ok. The second original is stuck into the last exiting rollers. The same happens if i make copies one at a time. The first is ok, but second is stuck. The sensors are ok, the rollers are clean. The second exit motor, doesn't work with the next page. on first page is ok. Any ideas?
Thanks.
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; As you said everything is ok, then the only thing you need to do is solenoid problem, replace it. but make sure exit roller clean enough.
Posted on Jan 12, 2009
Estudio232 error C550
RADF I/F error: Communication error has occurred
between the RADF and the scanner.
Apr 11, 2015 | Toshiba E-Studio 232 estudio232
Toshiba E-Studio 232 PhotoCopy Too Light, Why?
one simple way that may help you out , take out toner cartridge shake it to equalize toner powder , try it may work
Jul 25, 2014 | Toshiba E-Studio 232 Copier, 232 Digital...
A smudge appears on every copy of my photocopies. Why?
please clean the glass and laser ,otherwise change the drum and blade
Mar 05, 2014 | Toshiba e-Studio 232 Black and White...
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
It shows in the screen place doc.feeder in the down posotion
90% it is the RADF PCB. Before replacing it check the sensors and switches of the RADF in 03 mode. Refer to page no 2-29 of SERVICE HAND BOOK.
Dec 05, 2012 | Toshiba e-Studio 232 Black and White...
Can you scan a double sided document?
If you have e-Studio 850 of course.
Put original in RADF or glass
on control panel press copy function
on lcd you will see option simplex (see picture)
press it and in sub menu press option Duplex 2-2
set number of copies and press start
that is all
enjoy
BR
Feb 07, 2011 | Toshiba E-STUDIO 850 Copier
I have a message coming up that I don't know what it means.
ADF = Auto Document Feeder (Usually on top)
RADF = Rear Auto Document Feeder, (On the back)
Something is stuck in one of these, a piece of paper, foam, paperclip, twist tie . . . it could be anything. Follow the squealing sound and check the paper feeder rollers.
Find what is in the way and remove it.
Cheers.
Jun 22, 2009 | Toshiba e-Studio 161 Copier Copier
Toshiba e-Studio 232 Black and White Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
