Question about Sewing Machines
The feed dog as dropped down on my Janome 1570, does anyone know how the put it back so I sew again? thanks
Urgent need to get the machine working again, I have lots to do for my daughter's christmas fayre. Thanks
  • nathalie griffiths Dec 09, 2012
    Has anyone got any idea? really need help on this pleaseeeee!!!
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
  • 323 Answers
SOURCE: janome 8000 memory craft embroidery/sewing machine
on the backside of your free arm there is a small lever which can be moved to lower the feed dogs.
When you want them back up move the lever the other way.NOTE!!
They will not go up until the machine has made one revolution.
sewman7
Posted on Jun 04, 2008
SewTechWayne
  • 186 Answers
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
SOURCE: I have a janome 1600p. how do i drop the feed dog
there is a little metal plate that fits over the feed dogs, this is what I am using
Posted on Dec 26, 2009
I Inherited a Janome 1560 sewing machine, which didn't come with a manual, which I will download but cannot see how to drop the dog fed's completely down so that I can free motion quilt - Help
Here's a manual:
Janome 1560 Instruction Book
Page 36 of the manual states that you need to use the darning plate, ie the feed dogs do not drop on your machine. Instead, you put on the darning plate to cover the feed dogs.
Apr 09, 2018 | Janome Sewing Machines
Janome JF1004 - Lowering the feed dogs
Consult your owner's manual on page 30. Your machine requires an accessory called a "darning plate" that covers the feed dogs.
Janome JF 1004 Instruction Book Page 32
Jan 17, 2016 | Sewing Machines
How do I get the sewing needle to move forward on my Janome sewing machine?
Check to see if the feed dogs are lowered. There should be a lever or switch on the front or back of the sewing arm that drops the feed dogs for free motion sewing.
Also check under the needle plate for lint build up. This can prevent the feed dogs from raising.
Feb 25, 2015 | Janome Sewing Machines
I have a Janome 900 MC and I am trying to embroider a label and can't get the carriage to move, it just sits there in one place. I have tried lowering the feed dog and was told to raise it back. I have...
when the feed dogs are in the down postion the machine stay in one place
when the feed dogs are in the up positon then the machine will sew
if the machine still doesn't sew when the feed dogs are in the up position the feed dogs need to be checked to see if they need a adjustment or need to be replaced
Oct 14, 2013 | Janome Memory Craft 9000 Computerized...
My janome machine model 2001.doesnot work properly it thread is loose from down side during sewing ,sometimes work properly but some time while sewing it shows same problem i was cleaning with tooth brush...
I think you may have to careful clean everything and check you havn't dropped feed dogs or changed a setting. I don't really know what you mean by the foot getting stuck, but if the feed dogs ( moving part under the cloth) are down than the cloth can't move. Also, the pressure of the foot may be too high; this can also happen accidently while cleaning.
Get a manual ( sewingmanuals.com) and double check everything. Also, check there is no thread in the thread guides as this may have been your original problem. pull a thread towards to needle
Sep 02, 2010 | Janome 4612 Sewing Machine
Can the feed dogs be lowered? And need a manual....
Manuals will be difficult to find because the companies limit themsleves to the amount of spares they make, open the slide plate and see if there is a drop feed lever, if not you may have raised plates instead.
Mar 06, 2010 | Janome 8080 Computerized Sewing Machine
How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Aug 25, 2009 | Janome Memory Craft 5700
good luck!
Feb 08, 2009 | Janome Memory Craft 4800QD
Sep 20, 2008 | Sewing Machines
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
