Question about Lexmark X5470 All-In-One InkJet Printer
Faces on people appear to be longated when printed.
Faces appear longer than normal
  • Official Brand Answer
  • 3,344 Answers
It depends on the application that you're printing from. Make sure not to use the fit to page option. It would have been helpful if you indicated the application you're using.
Posted on Dec 10, 2012
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
Tip
Purchasing sunglasses for round faces
This facial type is easy to spot as the face is completely rounded within minimal check-bone edges and the face is circular. Buy a pair of sunglasses that makes your face appear to be longer. A larger plastic square type frame suits this face very well. The large plastic square frames add some angle to the face and really help balance the face out.
on Nov 07, 2010 | Clothing Accessories
Orange faces
Under printer driver properties clean the print head.
Use only genuine ink crg.
Use only genuine photo paper.
Jul 02, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Faces show up dark and unrecognizable
How far away are the faces? The flash on a typical point and shoot camera has a very short operating range, typically 3 to 15 feet. If something appears in the picture ahead of the faces, the flash will shut down prematurely and underexpose the faces.
Aug 12, 2009 | HP Photosmart R847 Digital Camera
Printing emails no longer possible
I found a solution here.
It says that you have a registration problem with ole32.dll
You can fix it by running the following at a command prompt.
regsvr32 ole32.dll
I hope it helps.
Apr 13, 2009 | Microsoft Outlook 2003 for PC
Lexmark Optra T610 prints distorted and broken text and images
try deleting the printer and drivers completely, then reinstall
Mar 11, 2009 | Lexmark Optra T610 Laser Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Dell 924 All-In-One printer
    Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
    • Letter*
    • Legal
    • B5
    • A4
    • A5
    • 3x6
    • 4x6
    • L
    • 2L
    • 5x7
    • Hagaki
    • 10x15 cm
    • 13x18 cm
    25 greeting cards,
    index cards,
    postcards, or photo
    cards
    • The print side of the cards faces up.
    • The cards are centered on the paper support, in between the left and right
    paper guides.
    • The paper guide rests against the left edge of the cards.
    • You select Normal or Photo print quality.
    25 sheets of photo
    or glossy paper
    • The glossy side of the paper faces up.
    • The paper is centered on the paper support, in between the left and right
    paper guides.
    • The paper is loaded vertically against the right side of the paper support.
    10 iron-on transfers • You follow the loading instructions on the packaging.
    • The blank side of the transfer faces up.
    • The transfer is centered on the paper support, in between the left and right
    paper guides.
    NOTE: For best results, iron-on transfers should be fed one sheet at a time.
    50 transparencies • The rough side of the transparencies faces up.
    • The transparencies are centered on the paper support, in between the left and
    right paper guides.
    NOTE: You can load a single transparency into the paper support without
    removing plain paper.
    Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
    Lexmark X5470 All-In-One InkJet Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
