Question about Sony VAIO VPCEE31FX Notebook
Replace wireless card - Sony VAIO VPCEE31FX Notebook
  • Sony Master
  • 27,725 Answers
Computer components have become more reliable than ever. Although many parts are now integrated onto the motherboard, it may become necessary to add or replace a sound, video, or network card due to component failure or the need for improvement. Integrated components can be left in place, and the problem solved by installing a second card into an available PCI slot. If a component such as a network card fails it can be replaced easily and inexpensively.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Turn off the computer and inspect the case. Remove the screws that hold on the removable side access panel. Remove the panel and lay the computer on the other side. Locate the network card. Inspect the rear of the computer to locate the network port. If it is a PCI-style card it will be the card with the single connection port on the rear face of the card. If it is a fixed part of the motherboard it will be located near the connectors for the mouse, keyboard, and USB ports. If it's a PCI card, remove the retaining screw and remove the card. Remove the PCI network card if present. Leave the case open and stand the computer back upright. Connect a keyboard, mouse, and monitor and restart it. Open the new network card and remove the installation CD. Insert the CD in the computer and follow the installation instructions. Shut the computer down again after the installation is finished. Lay the computer back down. Install the new network card in any available PCI slot. Replace the case and stand the computer back up. Hook up the keyboard, mouse, monitor, and a network connection. Restart the computer. Accept the default installation settings when the Windows Found New Hardware Wizard launches. Select No on the screen asking you to check for drivers online if it appears. The wizard should continue and find the newly installed drivers. Complete the Found New Hardware Wizard. Reboot the computer even if it does not ask you to. Open Internet Explorer, Firefox, or your favorite browser once the computer is running again. Ensure connectivity by trying several different websites. Hope this helps.
b>
Posted on Dec 08, 2012
How to replace the wireless card
The wireless card is located at the back portion of your laptop.
Read the manual of your laptop - locate the portion that indicate your WIRELESS NIC
Use a screwdriver to remove the screw.
Then gently press the locks on each side of the card
slowly remove the card
Replace the card and put back the screw
Thanks. Cheers!
Apr 21, 2010 | Acer Aspire 9300 Notebook
I cannot connect to my wireless because I was told that my wireless card went bad. What is the next step to get this corrected
how does an internal wireless card "go bad"? unless you got it wet and it short-circuited... but you should really be able to just download the broadcom driver and then the wireless driver. don't rate me on this, but i don't think it's your card, but rather your router. my router has been sucking teabags lately.
Oct 11, 2009 | Dell Inspiron 6000 Notebook
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | HP Compaq Presario 2200 Notebook
Laptop states wireless adapter not installed and configured? worked before.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
Need info on replacing zapped T41 modem with new card. Is this a simple switch? Or do I need to call in the Mod Squad? Len
I'm not sure what you mean by the T41 modem. If you mean the phone modem the it cannot be replaced because it is part of the motherboard.
If you mean the wireless card, then this can be easily replaced. To access this wireless card, remove the ketboard. There are four screws securing the keyboard and these are labeled with a keyboard symbol. After removing the screws the keyboard can be lifted up. The wireless card is located towards the top LH corner of the laptop and is held in place with screws, it also has two wires (for the wireless aerial) attached to the wireless card.
Aug 13, 2009 | IBM ThinkPad T41 Notebook
Can I upgrade the wireless card in a Gateway MX6454?
What you can do here is to get a new wireless card for your computer , you can get those new wireless card now in the market which uses the N standard already, You can check them from this manufacturer Linksys, Netgear, Belkin and Dlink....
May 29, 2009 | Computers & Internet
Gateway MT6705 wireless card will not light
You would need to replace the wireless card. It sounds the light is broken in the device. Send it back to exchange for a new one.
Aug 30, 2017 | Gateway M-6755 Notebook
Fujitsu P1510 wireless card replacement
Some laptops have a modem or wireless card that clip onto the motherboard like how the RAM is fitted to the motherboard. This card is larger than the RAM and may have one or two wires connected to this card. If so you will be able to replace this card.
If the wireless is a chip and is mounted on the motherboard then it would be impossible to replace.
Your only solution to this problem is to buy a PCMCIA wireless card and insert into the laptop's PCMCIA slot or use a USB wireless device. You may have to go into the BIOS and disable the internal wireless device.
Nov 25, 2008 | Computers & Internet
Wireless card w 9242 - where is it in the 5100 Insperion???
On the Inspiron 5100, the wireless card can be accessed thru a door on the bottom of the laptop.
1) Remove AC power and Battery
2) Turn the computer over, loosen the captive screw (labeled "circle C") in the modem/Mini PCI card cover, and lift the cover away from the computer.
3) Disconnect the Wireless card from the attached cables. These are the Antenna wires.
4) Use your fingertips to carefully spread apart the securing taps on each side of the Wireless card until the card pops up.
5) Remove the Wireless card.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 29, 2008 | Dell Inspiron 5100 Wireless Mini-pci...
Sony VAIO VPCEE31FX Notebook Logo
161 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
