Question about Roland Music
How to change Roland VGA7 guitar amp batteries?
3 Suggested Answers
  • 5603 Answers
SOURCE: ROLAND GR30 POWERS UP BUT DOES NOT MAKE A SOUND
Make sure you use the ORIGINAL AC adapter with the unit. It takes a 9VAC one.
The adapter for the GR09 will NOT work and will act the way your unit is acting.
Posted on Oct 06, 2009
  • 5603 Answers
SOURCE: Roland AC-60 Amp input impedances ?
I will solve the mystery...
The impedance varies depending on how you connect. It would be too complicated to explain the impedance to the average person.
From the schematic we have the TRS 1/4 inch jack having basically 100K and parallel 220 pf cap to ground EACH signal line and 10K resistance between. (The TRS jack if used disconnects the XLR and its components)
If one uses the XLR jack, one has an ADDITIONAL 100K each side in parrallel to ground PLUS an ADDITIONAL 2.2K resistor shunting between.
In ADDITION to the above, there is effectively 160K ohms to ground each side that is the input resistance to the input OP-AMP.
The effective impedance will depend on how and where you measure it.
Not sure what peizo you are using... For one on wife's violin we go into a X2 wireless which has about 1.6 Megohm. The receiver of course is fairly low impedance drive to the amp.
For the violin (Autolycus) pickup and others, severe distortion of the waveform existed when run directely into most amps and of course long cables worsened it at the high frequencies.
Posted on May 20, 2010
How do I connect my roland piano 5500 to an amp
On the rear of the piano there will be two 1/4" jacks labeled Output Left and Right. One will be labled Mono as well. If you are using a stereo amp, use both, and if a mono amp use just the mono output. If your amp is a guitar type, connect a shielded cable with 1/4" phone jacks such as you'd use with an electric guitar from these jacks to your amplifier. If you are useing a home stereo amp, you will need a cable with 1/4" phone jacks from the piano to RCA phono jacks on the amp end.
Oct 08, 2014 | Roland HPI-7F 88-Key Digital Piano -...
Roland troubleshooting
Are the speakers hooked up? volumes up? Is the guitar using active pick-ups? if so, is the battery good? is any noise coming thru the amo?
Jul 18, 2014 | Roland Ac60 Acoustic Chorus Guitar...
Roland Micro Cube Amp fuse blew out. How do you fix it?
have a look here:
http://www.ehow.com/how_8698510_fix-roland-cube.html
although it doesn't mention the fuse you will probably find it. Sometimes there is a fuse access on the outer case.
Jan 11, 2012 | Roland Micro Cube Battery Powered Amp...
I have a Roland AC-90. During a gig last Sunday I had my Taylor acoustic guitar and a Shure mic cutting out. There would be a break in sound - both guitar and voice would go - and then it would all come...
I would expect there is bad soldering or a circuit board crack. Inspect the soldering aound the leads, especially pots and heavy components. Finding all the retaining screws can be frustrating. Expect the screws for the handle to also attach to the amp chasis. They are often hiodden under plastic caps.
May 31, 2011 | Roland Ac-90 Acoustic Chorus Guitar Amp...
In what year is my roland jc120b from ? serial number zx57592
My Roland JC120 have JC-120UT Serial N. ZO18727, what year is it?
Apr 07, 2011 | Roland Elektronische Musikinstrumente...
Roland micro cube dosnt power up
Check the fuses. There is probably one on the outside of the amp and some inside the circuit board.
Apr 01, 2011 | Roland Microcube Guitar Amplifier
Brand new chromatic tuner tu-3 pedal, plugged guitar into input and it powers on. Guitar plays through the amp, but when I hit the footswitch the check light and tuning bar do not light up.
Change the battery first. It could be dying and just barely have enough power to come on at first, but not to do anything else. If that doesn't solve it, you've got a defective one and you can go exchange it.
Feb 24, 2011 | Roland Boss Tu-3 Chromatic Tuner Tu3...
Oct 04, 2009 | Roland Music
Music Logo
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
