Whirlpool cabrio makes humming sound and won,t drain
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Check the pump for an article of clothing that may be jamming the pump.
Posted on Dec 07, 2012
huuum
  • 750 Answers
SOURCE: Cabrio won't drain/spin, loud hum
Hello karlatw
Welcome
It sounds like the motor coupler is broken. Tilt the washer back &look on the floor for rubber or plastic shavings. This would indicatethat the motor coupler has failed. Another possibility would be thetransmission or drive block.
http://www.managemyhome.com/mmh/answers/Answers.action?intcmp=MMHxG_HomexAnswers_
Widget#l4q122032
Unfortunately you need service for this repair!
Please remember to leave a solved rating before you sign off!
Thank You
Posted on Dec 21, 2008
  • 109 Answers
SOURCE: Whirlpoll cabrio wsaher won't drain
If this a electrical pump chk. to see if there is an in line fuse if not then take the hose loose to see if the impeller has any thing hung in it or it could be a bad spot on your timer
Posted on Aug 22, 2009
SOURCE: Filled with water, will not drain or agitate,
Agitator dogs, I go through a set every 2 months. It has gotten so I can replace them in 3 minutes.
Posted on Sep 28, 2009
tunde007
  • 2382 Answers
SOURCE: Whirlpool cabrio washer wtw6600sw2 continues
Hi, the humming is coming from the washer motor, and it is either the motor is running or not running. If the motor is NOT running, or spinning, then the transmission may be frozen and in that case you may need to replace the washer, as transmissions are about $165 for just the part.
But if the motor is running, all you need do is to check the belt or motor coupling as your motor is not engaging properly.....
Posted on Nov 20, 2010
richroth
  • 9472 Answers
SOURCE: Whirlpool cabrio WTW6700TW1 only fills little bit,
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Posted on Jan 16, 2011
Testimonial: "Thanks. Quick and helpful. Need to call for service!"
Wtw6300SWO code dl hum and smell
http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
This has all the tests that you need to run and has information on tech sheets that are included with that machine.
Feb 09, 2014 | Whirlpool Cabrio WTW6300SB
My washer, Whirlpool Cabrio, sounds like it is draining water when turned on but continues to make this sound and will not begin wash cycle.
Hi Jane from retired Englishman in SW France,
Normally I would advise cleaning/clearing the drain filter but for some reason the Cabrio does not have an easily acccessible filter fitted just before the drain motor like other washers of other (sensible!) manufacturers.
So- it is really a case of having you, or someone else, check the drain motor itself to see if IT is blocked and the drainage pipes/system. Sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 02, 2011 | Whirlpool WTW6400SW Cabrio Washer
Washer will not drain or spin
http://www.fixya.com/support/r4604609-washing_machine_washes_but_wont_drain
Apr 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Aug 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Hello karlatw
Welcome
Widget#l4q122032
Thank You
Dec 09, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Dl error will not clear
My Whirlpool cabrio is making a humming noise an the water filled the tub but wont drain i tried pressing buttons but no luck please help,how do i reset it
Sep 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
