Question about Marantz Audio Players & Recorders
I have a marantz av550 pre amp/tuner. One of the audio outputs is not working. It had been cutting in and out for a while and now no output. It is not the cable, the amp or the speaker. Is this so
Used to go to alternate between working and low level of sound with lots of buzzing but now got getting anything.
  • 22 Answers
It sounds like the output transistors went bad What I would do is check all output transistors in the unit they are usually the large transsistors on heat sink that an ohm meter and check each transistor while unit is off and no power go base to collector then emmiter to base if you get o or continuity on those legs on any one they are bad .
Posted on Dec 08, 2012
2 Suggested Answers
  • 101 Answers
SOURCE: marantz pm730 pre amp works ok no sound from main
Look at the final out transistors. I'm not sure if you would have transistors or an amplifier pack? It has 8 to 14 pins maybe. Look to see if there are any burnt components,cracks, or where something got hot. Most components break down because of heat.Also look for bad solder joints.
Posted on Oct 23, 2009
How to hook a carver TFM 45 to a Marantz AV 8003 pre amp with Bose 901 speakers thank you very much
The output of the Marantz will go to the input of the Carver. The Bose EQ has to go into a Tape Monitor on the Marantz, or, you can connect the Marantz output to the Bose line in(not tape in). The line output of the Bose, to the Carver input.
Is there anything else I'm missing?
Jan 08, 2015 | Marantz Audio Players & Recorders
How do I connect my marantz pm8200 to TV
You can connect TV RCA outputs to any line input e.g. tape, tuner, CD etc on the Marantz. If your TV doesn't have separate RCA outputs use a 'scart to RCA audio outputs' adaptor... TVs have a standard line output level compatible with most if not all hi-fi.
Aug 12, 2014 | Marantz Audio Players & Recorders
How to output sound to a 2nd device
If you need an analogue output, you can tap stereo analogue audio by using one of the two sets of "pre-out" RCA jacks on the back of your receiver. These provide "headphone like" output power, and will not overload any analogue input connected to it EXCEPT MIC and PHONO inputs on the 2nd device. If it's digital audio output you need, there's an HDMI monitor out, that will provide digital audio to another HDMI input equipped device. You'll have to get a relatively cheap adaptor if you need this digital audio output in another digital format/connection (like the popular S/PDIF optical or coaxial).
Jun 11, 2014 | Marantz NR-1604 7.1 channel HT receiver...
One side not working
the 2230 is a fine unit! There could be several things causing this problem, more than likely it could be dirty front controls which will require cleaning. It could be more serious problems such as pre-amp or main amp failures, dried up output coupling cap for the right channel. I would recommend having the unit serviced. These older vintage Marantz units are really special and deserve proper attention.
Thanks
www.back2lifeelectronics.com
Jan 21, 2013 | Marantz 2230
Is there anything in particular I need to do to use the digital outputs of the Marantz pmd340? My ps audio dac works with a rotel cd player automatically but I can not get it to work with the marantz with...
You may have indicate on the CD player that you wish to use the Optical output and then even when that is correct there are different bit rates that may not be compatible with the input of the amp.
Dec 26, 2012 | Marantz PMD340 CD Recorder
No sound on SR18
One of your five amplifiers has blown its output transistors. Unfortuately, with SR18s, many components down the line from the outputs get fried as well, and (in my experience, anyway) it usually takes hours to track down all the problems. You can still use the unit as a preamp/tuner/surround processor by taking signal out at the pre-out jacks (you have to remove the five jumpers), and feeding it into external power amps, but repairs to the SR18's amp are probably going to be costly and complex. Sorry about the crummy news - hopefully I'm wrong!
Sep 03, 2009 | Marantz SR-18EX Receiver
My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
Aug 11, 2009 | Marantz DV-9500 DVD Player
Marantz amp will not put out any sound
If it went out with no indications of trouble it's probably a fuse in the output circuit. It might be an out put amp but typically they let you know they're going bad with a little noise.
Feb 16, 2009 | Marantz Audio Players & Recorders
Multi Room Function on marantz SR-19
Hi..
Put a RCA (phono cable) splitter at the pre-out /main in.
That way you can go to both amps with the same signal
Jan 14, 2009 | Marantz SR-19 Receiver
Stereo connection
Hi spanky
Sorry for the delays in getting back to you. Been busy here this week.
OK. to connect the 2275 to the 1152,there are 2 ways of going about this.
You can plug the pre- out of the 2275 to the power amp-in of the 1152. In doing this you are using the power amp section of the 1152 and the preamp functions of the 2275. Your other gear like CD player, tape deck and so on also plug into the 2275.
the other(better) way is to plug the pre-out of the 2275 into the tuner inputs of the 1152, leaving the volume at about 40% on the 2275 and use the 1152 as an integrated amp. This means you are using the 2275 as a tuner only. When you do this, you will need to use an RCA lead to jumper the pre-out/poweramp-in connections on the back of the 1152, and the 2275 ... L to L and R to R respectively.
I am still wondering why you want to use 2 integrated amps (each having a preamp and a poweramp section) The only real benefit the 2275 brings to your system will be tuner functions. You could just get a tuner and run the 1152 to be an ideal rig.
Let me know what your ideal setup you are wishing to build would have. Speakers, other gear like CD, tape deck, etc.
regards
robotek
Jul 23, 2008 | Audio Players & Recorders
74 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
