Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Pt-53TW53 issue hi...seems to be an issue that is familiar on here!! TV on for varied times then shuts down-red light blinks 3 times...stops, then repeats...no power for TV...unplug TV, then on for say 5 minutes, sometimes 10 mins...then gone again...I believe that the I,C's in DG board a problem...can you help me to locate this board and is it easy to repace these parts??? Thanks,
    Genius:
  • 1,011 Answers
ONE: Bad convergence. Repair is about $400.
TWO: Bad power supply
No it is not easy to replace the parts. If u have knowledge in electronics try it service manual.
Thanks
good luck
Posted on Jan 13, 2009
  • 45 Answers
I had the same problem and stumbled on the fix. It seems there is a factory defect. Open the lamp cover and you will probobly notice that the blue shut off switch on the left side is landing on top od the lamp cover. Reach down with a pencil or something and make sure the switch is under the tab on the lamp cover. My 50 DLP has not shut down since I set the switch properly. Free fix... try it.
Posted on Jan 12, 2009
    Scholar:
  • 160 Answers
Yes its the problem of the main board and the ic parts needs to be replaced.but it is not safe to handle high voltages like tv if you r not familiar.
My panasonic rear projection tv does not turn on the red light blinks 3 times
3 times red light blinking indicates that tv got problem of convergence output ICs failure and need to replace two big black ICs (convergence output) to solve this problem.
IC replacement requires soldering work and good knowledge of electronics stuff repair, please cal local tv repairman if you do not have prior experience of such work to avoid any damage.
Hope this will help.
Thanks.
Feb 28, 2011 | Panasonic PT-53TW53 53" Rear Projection...
My panasonic pt-53tw53 wont turn on. The power light blinks 3 times then pause then three times....etc. If I unplug the set and plug it back in, it will work again but just for a short time, then shuts...
The 3 blink error is the convergence circuits need repair. The Panasonic repair kit PT53WX53 convergence repair kit is the correct kit for your model. Its available from www.tvrepairworld.com and the kit contains the parts and the CD with instructions.
Sep 22, 2010 | Panasonic PT-53TW53 53" Rear Projection...
I have a Panasonic PT-53TW53G that stopped working. Red LED light blinks 3 times. Any advice?
the 3 blink error means the convergence has failed and has shut the set down. You can get the convergence repair kit for your model at the following link www.tvrepairworld.com The kit contains the parts and the Cd with detailed instructions
Sep 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53; Red shadows appear and then the t.v. shuts down.
The convergence output IC's have failed. Only fix is to replace them. These are large amplifier IC's bolted to heatsinks and have a high failure rate in all projection sets.
Jun 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic projection tv
Standby light blinking 3 times means a convergence error. The two convergence IC's need to be changed Panasonic part# C5AA00000203 (do not substitute with a generic STK#) This is about a $300-$400 repair.
Sep 23, 2007 | Panasonic PT-53TW53 53" Rear Projection...
No sound, No video, power LED blinking 3 times
had the same problem with mine and I replaced horizontal deflection transistor located by the high voltage tranformer, its the big transistor by the heatsink, check for any shot and replace if you find problem. worked for me
Apr 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
