I turned on my tv and all i get is changing colors on the screen but no picture or settings
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Unplug the set and a box or receiver if used from power for several minutes and plug them back---cannot hurt and may allow set, box etc to reboot and work again.
Posted on Dec 08, 2012
Sony tv screen turns green
Use the remote control to go into your TV picture settings menu and change the mode to NATURAL. It's also a good idea to check that all of your cables are in good shaped and tightly connected.
The green color could signify that your TV is magnetized. This can cause colors to draw out to the corners of the screen. Remove any magnetizing devices, like speakers, away from the TV and see if that helps.
For more solutions, read the troubleshooting steps outlined in TV color problems. I hope this helps!
Sep 12, 2012 | Sony Internet TV NSZGT1
What are the menu settings supposed to be at for the color, picture, what do I do if the color is not right, pickish and green
Go to tv menu go to screen setting turn screen contrast to the max and screen brightness half midway point like 55.Tv real old like around ten years?Watches alots daily like 6 or 7 hrs a day?The tv CRT-(tv tube) might be to old,the radiation colors guns R,G,B insisde might not work as well as before.Have a reset setting in the colors setting?Go down to that press that,to restting for the factory colors setting.Or tries add more blue,a bit less green and red,see how that turn out?
Feb 05, 2011 | Panasonic CT-32G23 32" TV
What is the perfect calibration for this television.
Go into the tv menu setting,at the picture setting go down to reset it back for the factory setting.Now,go to the color setting turn the colors setting down anothter 20 precentage for reductiion of colors.The picture should great now,because this is factory setting,but it just a bit to much colors on the screen pictures.
Dec 15, 2010 | LG 32LE5400 32 in LCD TV
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Jul 23, 2010 | RCA F19431 19" TV
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
Picture Rolls
anteetina,
most probably your problem is within color system settings. It's either PAL/NTSC or PAL SECAM signals being produced by your player.
1) try to check your TV screen with regards to color system it use, check the color setting if it does indicate "Auto" "PAL" or "NTSC" try to choose "auto" and see if any changes will occur.
note: you can also check the service manual of your DVD player of what color system it produce and if it's match with your TV screen
cheers.
mark
Jan 15, 2009 | Digix HT1056A DVD
TV turns on and then, after a few seconds, picture changes to "double vision".
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | RCA P46921 46" Rear Projection Television
Haier P42LV6-T1 picture
when TV overheats white lines come across the screen
May 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Red picture toshiba model 50h71
try to turn down the screen control and see how the tv reacts.
Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
