Question about Craftsman Garden
Gas in the oil
Whet to change oil and there is gas in the oil alot of it can any thing be done and why is this happening
    Problem Solver:
  • 8 Answers
The float in the carberator is sticking. Clean the carberator and if that doesn't work you can put an inline gas shut off.
Posted on Dec 08, 2012
Gas and oil squirting into air box
First of all, there should be no gas/oil mixture on this bike. If it is a crankcase breather and it has gas coming out of it then it means that gas has ran into your engine and diluted the oil. Check the oil and if this is the case then drain and change immediately. As for the gas getting into the crankcase; if you have a float stuck in the open position in your carburetor the gas freely runs through it, then into the cylinder where it then leaks past the piston and into the case. I hope you engine isn't filled with gas but it sounds like it is. If this is what happened then the oil change will fix your problem. If so, take the carburetors apart and make sure the needles and seats are clean and move freely to prevent it from happening again.
Jun 08, 2012 | Motorcycles
Smoking bad and bad miss and smells like gas in the oil on 1992 toyota paseo
I would look towards the fuel pump to see if there is any possibly way that it has failed and is leaking gas in to the oil. I have heard of that happening.
Another possible thing to check is ring wear, if your rings are to worn you will have blow-by which could cause gas in your oil.. Do or have done a compression test and see what your compression is. If the compression is low squirt a little oil in to the low cylinder and retest if the pressure comes up your rings are bad and that could be where your gas in your oil is coming from. If the pressure does not come up you have a bad valve. Seems to me that there should be no more then 15% max between high and low, any more then that needs to be repaired.
Nov 25, 2011 | Toyota Paseo Cars & Trucks
My 2009 ford focus starts sputtering sometimes while idleing or not moving but on. But doesnt turn off randomly by itself. And it started an afternoon after an oil change about a few months ago. whats...
Tire issue is due to improper camber angle, needs to have a front-end alignment done. The sputtering after an oil change could be due to whoever changed it didn't put the proper grade of oil in. Other possibilities could be bad gas, fuel filter however that doesn't make since seeing how it happened after an oil change. So check to make sure oil level is not overfilled, and the filter is inserted correct.
Jul 11, 2010 | 2009 Ford Focus
Overall maintenance and tips to keep my lexus 1992 es 300 running smoothly it has 230000 miles. I get oil changes every 5000 miles put good oil in the car. I put good gas in the car and every time i fill...
I would not mess with Oil Treatments, what you have been doing is fine. I would change the fuel filter, if it hasn't been done for a while. Also a transmission service. Check your belts and hoses.
Jun 14, 2010 | 1992 Lexus Es 300
My oil pressure gauge drops to zero when the vehicle slows. oil level is full. had oil changed recently and it was thick so they added a solution to keep that from happening. the gauge reads fine when the...
IT COULD BE ONE OF MANY PROBLEMS THAT CAUSE THIS
1 THE SENSOR IS BAD
2 PLUGED OIL PASSAGES IN THE ENGINE
3 BAD OR FAULTY OIL PUMP
4 ROD BEARINGS OR CAM BEARINGS EXCESIVE WARE IF YOU HAPPEN TO DO ALOT OF HARD STARTS (FLOORING THE GAS PEDDLE) THINGS LIKE THIS HAPPEN TO WEAR DOWN THE BEARINGS VERY FAST IF THE JEEP HAS OVER 130,000 MILES ON THE MOTOR THEN i WOULD LOOK AT HAVING A REBUILD DONE BEFORE THINGS GET REAL BAD IF YOUR PLAINING ON KEEPING THE JEEP FOR SOME TIME ONLY WAY TO BE SURE IS TO TAKE IT IN AND HAVE THEM DO PRESSURE TESTS ON THE MOTOR AND SEE WHAT IS GOING ON (CHECK PRICES FIRST) DEALER WILL HIT YOU AT (MY AREA) 54.00 PER HOUR YOU MIGHT BE ABLE TO FIND SOMEONE WHO KNOWS WHAT THEY ARE DOING AT ONE OF YOUR LOCAL PLACES THAT WORK ON ENGINES AND SMALL PROBLEMS
Apr 29, 2010 | 1996 Jeep Grand Cherokee
Gas in oil
this occour generally when the compression on cyls. is poor
Mar 20, 2009 | 2000 Jaguar S-Type
Oil light when idling
Have an oil pressure test done.
One of 4 things could possibly cause that.
Bad oil pressure sending unit.
just the oil sending unit.
weak oil pump.
low oil---check oil, see if it needs any.
Mar 12, 2009 | 2005 Chrysler 300
F150 oil pump Replacement
If it has oil pressure at idle I would say the pump is good. I would try hooking up a mechanical gauge(oil pressure tester) and drive the truck with this on it to verify the pressure. The funny thing is what you are describing to me sounds like a restricted oil filter.
Mar 02, 2009 | Ford F-150 Cars & Trucks
I got my oil changed about 2 1/2 weeks ago and about a week ago my car started running rough, i attributed it to maybe a tankful of bad gas. this morning the engine was knocking and i made a mental note...
I had Walmart give me an ambassador package oil change years ago on a grand am and the nimrods never tightened the filter and the same thing happened to me. Even though I put oil in the engine seized within 48 hrs. Good luck! Get your documents ready because whether or not your engine fails you will still want to sue the oil replacement service worker for subsequent damages due to negligence.
Jan 19, 2009 | 2005 Suzuki Forenza
2002 Oldsmobile Alero heating up
I happen to own a 2002 alero, and alot of people says the same thing about theirs. You may need to replace you head gasket and run more antifreeze than water.
Nov 01, 2008 | 2003 Oldsmobile Alero
Garden Logo
23 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
