Question about LG WM2688HWM TROMM SteamWasher
How to re-attach a door boot
I bought an LG Tromm front loading washe and dryer. The door boot has mildew in it. So we got a new one. We removed the old door boot, but can't figure out how to re-attach the new one. The service technicians want to charge us $200 to fix it. I'm not paying that especially since it's their poor quality machine that has caused my problem.
  • meghanisaacs Jan 12, 2009
    Thank you for that helpful advice.
    Stradeteox, the problem is that we cannot seem to get the gasket to fit around the rim on the inside... the gasket seems just a little to small. We can get it all the way around except for about a 6 inch span, but when we try & push that in it pops out around the other sides...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
The door gakset is held on by a round ring on the inside of the drum and another round ring on the outside (where the door meets the gasket). Make sure the gasket is oriented correctly, then starting either on the inside or outside, stretch the ring to fit over the gasket and into the channel. There is a spring on the ring clamp that allows it to be stretched. It is easiest if using 2 needle nose pliers - 1 to hold the ring and 1 to stretch the ring by grabbing the loop where it attaches to the spring. You should be able to stretch it far enough to get the entire ring to fit over the gasket and then onto it before letting it go back into position. Be careful not to tear the gasket. Try to orient the ring so the spring is in the 10 o'clock or 2 o'clock position (to avoid door leaks). Hope this helps.
Posted on Jan 12, 2009
Front loading washer door should it be left open or closed when no use.
I recommend leaving the door slightly ajar when not in use. That way your rubber boot/door gasket doesn't get smelly or stinky.
-Colleen @ MendingShed
May 05, 2015 | LG Tromm Front Load Washer And Dryer Set
The rubber gasket has mildew. Can it be replaced?
yes you can replace the rubber gasket, body and door may need to off
Sep 10, 2012 | LG Tromm Front Load Washer And Dryer Set
We have an LG Tromm Steamwasher WM2487HWM . 4.0 cu ft front loader....I see a lot of complaints about mildew and smell...we have the same problem....is it safe to take teh rubber seal off the washer to...
Replace the boot with new. While you have top and front off to replace boot, hose the drum down with a hose on stream. Remove filter clean out as you hose it down. Btw, there is no cleaning off the boot if it has mildew/mold on it.. it's slightly porous and no eliminating it
Aug 05, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM -WM1814CW I bought the washer and dryer
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@(((
Aug 09, 2010 | LG WM1814CW Front Load Washer
Musty/Mildew smelling clothes...
lg has a known problem with smelly mildew cloths. If you call LG they will tell you its not there problem. Cheapest solution is to wash door gasket with some clorox and then betwen washes leave door open. On the washing supply shelves there is a product you put in the washing machine run a wash without cloths and it does the same thing except it costs $7.If you bought it a t Lowes go back and ***** to store manager my friend did exactly that and got the machinje replaced
Sep 30, 2009 | LG WM2688HWM TROMM SteamWasher
LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Jul 26, 2009 | LG WM-2277HW Front Load Washer
Rubber gasket removal LG Tromm front loader
We found there is three small holes on the seal right inside the door, check to see if they are clogged with soap scum and clean them out. Run a cycle of hot water and bleach. Then, after each use, leave the door open and let it air dry and this has seem to work.
Jul 06, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM Model WM2077CW-mildew on rubber
First and foremost you MUST use an HE detergent, HE(high efficency) is design specifically for fontloading machines.. and use little amounts of it, 2-3 tablespoons is all that is required to clean a full tub of clothing.
Jusst using less of regular detergent is not the same as using correct soap. the moldy smell and black filth when the front bellow is pulled back is actually residual detegent not being disovled in normal operation , all front loading washers are experiencing this issue, there is a new product on the market to help combat this problem and for the 1-2 months ive been reccomending no one has told me that it hasnt helpd. heres the link www.affresh.com
Apr 09, 2008 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
202 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
