Question about Chantal Whistle Tea Kettle
My chantal tea kettle wont whistle
The whistle part of my tea pot fell out. I screwed it back in both ways and still no luck. How can I fix it?
Where can I buy another screw for my Chantal teapot whistle?
You can try and source one from the manufacturer or maybe easier to simply try a local hardware store and try to locate the correct one.
Jan 05, 2015 | Chantal Classic Teakettle, 1.8-Qt. -...
Can triggers be replaced?
Take it to a repair man, or mostly, just purchase another kettle...whe they start to break, better another new one, because tempering will lead to more frustration or worse, eletrocution.
Jun 14, 2014 | Alfay Designs Inc Remedy Metro 1.5-Quart...
Oster kettle not working
Ultimately, how I ended up fixing my Oster 5965 and Hamilton Beach Cool Touch Electric 40898 kettles that had the same problems as you (Nothing would work; no heat, no buttons would light up) was by taking apart the bottom screws (Be warned, for only one screw I needed a "Spanner Insert Bit"). I jiggled the connectors as I rang them out with my multimeter and everything seemed to work. Leaving the bottom off I retested the kettle and it just worked. I reassembled the parts and made my happy wife a cup of English Tea.
Oct 18, 2012 | Oster 5965 Electric Kettle
Donot support the games
ho............ ang ganda patingin na mn yan
Feb 12, 2011 | Electrolux CHANTAL Loop Tea Kettle -...
How to clean the inside of tea pot (scale deposits)?
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
Jul 07, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
Alessi whistling kettle -- one whistle doesnt work.
you need to replace it with a new one it will be corroded. heat kettle then drive out pitch pipe with a screw driver from below, insert new one from above.
Sep 24, 2009 | Alessi Richard Sapper 9090/1
Will not whistle
It is possible the reed valve broke.
Aug 02, 2009 | Electrolux CHANTAL Loop Tea Kettle -...
Damage to the bottom of Cuisinart cordless tea pot mod KUA-17
Even though there are no parts listed at the cuisinart.com website, the company does a few base pieces left in stock if you call them directly - 1-800-726-0190
Apr 11, 2009 | Cuisinart KUA-17 Cordless Electric Kettle
The tea kettle stopped whistling...
I could be that you have some debris in the hole. Try running a pipe cleaner though it a few times and see if it helps.
Mar 18, 2009 | Kitchen Appliances - Others
Chantal Whistle Tea Kettle Logo
Top Chantal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Chantal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
