Question about Breville Fresca BES860 2Cup Coffee Maker
Two cup button makes a terrible electrical contact noise, when button is used, and the longer the machine is on, the louder the noise?
Machine is approx 2 years old, problem started 3 months ago, suddenly. Machine still fully operational, just making terrible noises each time coffee is made!
4 Suggested Answers
mirran
  • 515 Answers
SOURCE: coffee suddenly bitter
Have you descale your machine?
Posted on Jul 20, 2008
SOURCE: Espresso Machine Stopped Working
Mine stopped heating (pumped only cold water) and when I opened the top of the machine I noticed that the blue electrical cable to the thermal block assembly (probably to the thermal fuse, but I an not sure about that) corroded and was loose. I fixed the connection and since then the machine heats perfect.
Posted on Sep 18, 2011
ledajcollins
  • 5 Answers
SOURCE: My Breville Expresso machine does nothing when I turn dial to make coffee
Sounds like its time to clean it. Run white vinegar and a little water through it.
Posted on Apr 18, 2012
Machine making terrible knocking noise when in use?!
Sometimes this is caused by not having enough liquid in the recipe.
All flours are not made equal. Make sure you ladle the flour into the measuring cup with a spoon , then level off with the back of a knife. Scooping a measure into flour, impacts the flour and you actually get more flour than you need. If this does not help, try adding more liquid a tablespoon at a time and see if this works. good luck.
Apr 05, 2015 | Russell Hobbs 18036 Breadmaker Fresh Bread...
Breville making really loud noise when push espresso button
My machine started making a buzzing noise after the cleaning and descaling. It was still under warranty and I was planning to have it fixed by the manufacture but after a couple weeks of using it the noise stopped.
Feb 02, 2014 | Breville The Barista Express BES870XL...
Bosch washer noisy
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 22, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Two-Cup Button is Making A Strange Noise
Machine my need a new exshust valve try back flushing the machine with only a pinch of back flushing powder.
Feb 23, 2012 | Breville BES860XL
Dyson DC17 started making a louder overall noise
Hi there, from your description it sounds as though the machine has a blockage.
Try following the online diagnostics in the Support section on our website at www.dyson.com. Hopefully this will help you locate and remove the blockage causing this.
If you need any further help or advice, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 05, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Ticking getting worse!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
edgfd
Sep 30, 2009 | Bosch Nexxt 500 Dryer
Terribly load noise when washing
could need a new bearing
Jun 10, 2009 | Washing Machines
Can't get a full cup of coffee
First, you should not be using your espresso machine as an american coffee maker. It puts way too much pressure on the components of the machine. The standard cartridges are made to do 1.5 - 3.0 ounces of espresso. should you want to make a longer cup of coffee you need to get the aroma point gran caffe cartridges, lavazza code 427. this will enable you too get the longer cup of coffee without putting the added stress on your machine. Also it sounds like your machine mighy have a problem with the volumetric device. are you getting water in the capsule ejection drawer? should you want service you should call 781-393-2929. we are an authorized lavazza distributor and repair center.
Oct 09, 2008 | Lavazza Espresso Point Capsule Machine
Breville Fresca BES860 2Cup Coffee Maker Logo
46 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
