Question about D-Link DSL-2540B ADSL2/2 Modem with 4-Port Ethernet Router
How to block lan IP
Hello, looking for information on how to block a certain IP from all internet access, thanks in advance.
  • D-Link Master
  • 27,725 Answers
IP filtering is a method used to block computers on an internal network from accessing the Internet. This is often used on critical machines on the network, such as servers. It blocks users from accessing the Internet to protect these machines from malware. You can filter IP addresses on your router using the administrator console provided by the router's manufacturer. Once the block is set up, each user machine listed in the filter settings will no longer be able to access the Internet.
Open your web browser and type in the IP address for your router. For most default settings, the IP for the router is 192.168.1.1. Enter your admin username and password. If you have not set them up, try leaving the username black and the typing "admin" for the password. Click the "Security" tab at the top of the window. This opens a new console screen. Within this screen, click the "Filter" link. A list of text boxes is shown where you enter the IP addresses you want to filter. Enter a range of IP addresses you want to block. You can enter one IP address or several. Click the "Save Settings" button. Hope this helps.
Posted on Dec 11, 2012
I have bought my Acer 4820TG laptop a week ago. I have LAN port in my hostel room. when I try to connect the internet via LAn cable it says no internet access, but at the same time if my roommate on his...
Hello User
Did you Check you Local Are Connection Icon in your Computer? Maybe it has Dynamic IP Address!!!
Set it into obtain ip address automatically
thanks
Nov 13, 2010 | Computers & Internet
How do i setup my router to shut down the udp port at a certain time....xbox live is what i'm trying to control
Your router does not have the advanced features that would be needed to do this. However, this can be controlled using parental controls on xbox live. Here is a link: http://www.xbox.com/en-US/support/familysettings/xbox360/familysettings-intro.htm
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Router no connecting to the internet
You need to configure NAT on the router to permit the entire LAN to access internet
Example.
LAN Segnment is 192.168.1.0/24
1. Create an access-list to identify the local segment
2. Configure the Nat interfaces properly (NAT-INSIDE, NAT-OUTSIDE)
3. do the NAT configuration
i.e ip nat inside source list (ACLNUMBER) .....
Dec 08, 2008 | Computers & Internet
Unable to access Internet, WAN IP Address present
First you will need to open up your internet browser (Internet Explorer/Netscape) and go to http://192.168.1.1. You will be prompted for a username and password. By default there is no username and the password is admin. Once you arrive at the routers setup page click on the Advanced tab. Once the page finishes loading, you'll find you will be on the "Filters" tab. Look down and make sure that there are no numbers other than 0 in the boxes on that page. If there are, then you will need to replace them with 0's and click Apply, then Continue. Once you've done that, you're going to want to look for Dynamic Routing at the top, and then click on it. Once that page finishes loading, make sure that the "Working Mode" is set to Gateway, not ?Router?, and that tx and rx are set to Disable not RIP-1 or RIP-2. If a static IP address has been set on the computer, verify the gateways matches the Router's LAN IP Address. If there aren't any installed gateways, add the Router's LAN IP Address. When setting static IP Addresses, you must also input the DNS servers. For more information on assigning static IP addresses, please see the related article on assigning static IP addresses. If you?re still having difficulties, please contact Linksys Product Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL and Voice...
Feb 16, 2006 | Linksys BEFSR11 Router
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Feb 16, 2006 | Linksys WRT55AG Router
How do I setup filters on my wireless router?
IP Filters IP filters block access to ports or a series of ports from an IP address on the LAN. For example, if you did not want the computer with IP address 192.168.0.100 to access the Internet, then you would block that IP address from accessing port 80. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select IP Filters using the radio buttons. Step 5 Select the Enabled radio button. Step 6 In the first field next to IP enter the IP address you want to block access from. If you want this to apply to a range of IP addresses, then enter the ending IP address in the second field. Step 7 In the first field next to Port enter the port you want to block. To block a range of ports, enter the ending port number in the second field. Then select the protocol type (TCP, UDP, or Both) using the drop-down list next to Protocol Type. Step 8 Next to schedule select Always using the radio buttons to continuously enable this filter, or select the From radio button to set a schedule using the time and day drop-down boxes below. Step 9 Click Apply and then click Continue to save the new settings. URL Blocking URL Blocking is used to block web sites that contain certain keywords. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select URL Blocking using the radio buttons. Step 5 Select Enabled using the radio buttons. Step 6 In the text box below enter a keyword to block. To delete a keyword, select it from the box below the text box, and click Delete. Step 7 Click Apply to add the keyword to the list. MAC Filters MAC Filters allow you to allow or deny access to the LAN by specifying MAC addresses. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the (default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select MAC Filters using the radio buttons. Step 5 In the section MAC Filters, select the radio button for the mode you would like to use. Disabled - Disables this feature and will allow all wireless clients to connect. Allow - Blocks all clients except for what you enter in the list. Deny - Allows all clients except for what you enter in the list. Step 6 Enter the name used to identify the entry next to Name. Step 7 Enter the Ethernet MAC address that you wish to Allow or Deny next to MAC Address. Step 8 Click Apply and then click Continue to save the new settings. Domain Blocking Domain blocking lets you allow or deny access to certain websites. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select Domain Blocking using the radio buttons. Step 5 In the section Domain Blocking, select the radio button for the mode that you would like to use. Disabled - Disable this feature and will allow all clients on the LAN to access any website. Allow - Permits access to all websites except domains specified in the Blocked Domains section. Deny - Allows access only to domain specified in the Permitted Domains section. Step 6 In the Permitted Domains section, enter a domain to permit. In the Blocked Domains section, enter a domain to block. - or To delete a keyword, select it and click the Delete button. Step 7 Click Apply to add the domain the list.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
D-Link DSL-2540B ADSL2/2 Modem with 4-Port Ethernet Router Logo
101 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
