Question about Dryers
There is a burn mark in back of the timer and it sparked from touchen metal houseing now it wont come on at all wut do i do now
  • Dryers Master
  • 8,220 Answers
Can you post photos of the machine?
Posted on Dec 07, 2012
JVM 250vwoo1
Pry off plastic tab. Clean up burn marks with sand paper and touchup paint. Order a new rack clip. Also clean any burn residue off rack.
MOST IMPORTANT: After the repair, do not put the rack back in unless you are cooking on it. Running the microwave with nothing on the rack is what causes this to happen.
Sep 05, 2014 | GE Microwave Ovens
I wired my timer switch wrong i need to know which colors go where
The fuse is located on the heater housing we4x800 is the part number on most of these. Look closely at the wires on the timer each one has a letter on it the letters on the wire matches the terminal markings.
Dec 27, 2012 | GE DBXR463EDWW Electric Dryer
My dr 1990 model wont fire
try pulling the plug, stick a screwdriver in the end of the spark plug wire and hold it to the metal of the bike try starting it if it has fire you wil get a spark. if no spark try checking the points they may have burned out
... good luck
Jun 02, 2012 | Suzuki DR 750 S Motorcycles
Sparks from GE Microwave - HVM1540SN2SS
THERE SHOULD NOT BE ANY METALS IN A MICROWAVE WHEN THE UNIT IS RUNNING
If the unit paint is flaking and behind that flake is metal.. You need to throw it away or talk to your appliance guy and see if there is a speacial paint to coat the metal so you can use your MW
Jul 25, 2010 | GE Microwave Ovens
There is heat, but not nearrrrrly what it should be. The other day we noticed the metal coil thingy on the bottom ("bake element"?) do a weird thing, it turned very bright and a small bright spark spread...
That is what I would do. Be sure to remove the power plug before doing any kind of work on the elements or wiring. If the element is a 'plug-in' device, the repair is simple. But if the element connections are buried in the oven back, it requires more careful work. Hope this helps!
Feb 14, 2010 | General Electric Stove/Oven/Range Chrome...
Infinite switch sparking!!!!
You have a short somewhere between the switch and the burner connector. Probably a wire's insulation has worn away or melted and is allowing the wire to contact the metal housing somewhere. You will see arc marks wherever the short is located. Look carefully where the wire passes through any holes or where sharp turns are encountered.
Aug 12, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Flash/sparks occrred (no metal in oven)
You know I just had a similar problem on my old unit. There was a spark and my bowl had no metal rims. I figger your ground connection has corroded at the rivets. So if you can drill a 1/8 inch hole in there and install a #8 sheet mtal screw or two to bond it togeter again.
May 04, 2009 | Microwave Ovens
Timer knob doesnot move dryer will not turn off.
Clean the fabric softener off the metal strips located under the filter housing inside the dryer. If **** gets on them then they wont send a signal to the dryness board and advance the timer motor. Resistance is monitored between them 2 metal strips as yer wet clothes tumble in the dryer. Wetness is detected and the motor gets a no go. When the all clear is signaled up then they is happy motoring to the finish line.
Mar 15, 2009 | Dryers
Dryers Logo
Top Dryers Experts
