Question about Marantz SR5007
Surround sound not decoding properly
Digital decoding of the surround sound signal from my various hdmi inputs (ps3 and skytv digital), doesn't work properly. When set to auto it always plays stereo, regardless of the source (e.g. 5.1 DTS from a bluray played through ps3), and even if I explicitly select DTS or Dolby the sound from the left, right and surround channels is strange (DTS makes the trebble sound like it's a muddled/corrupted, dolby sounds like it's just old school pro logic, and neither of them sound like it's properly decoding the signal). The speakers are fine and play beautifully with an ordinary stereo source, and the HDMI sources worked fine with my previous receiver.
3 Suggested Answers
SOURCE: Marantz SR8500
Check the settings on your dvd player!. It might be set to PCM
instead of HDMI.
Posted on Mar 10, 2008
  • 905 Answers
SOURCE: No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
Posted on Oct 06, 2008
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
How do I hook up my receiver to my PS3 player and create a surround sound. The amplifier is already connected to a dvd player which is already in surround sound but I can not do the same with the PS3.
If your receiver has another digital audio input available to connect to, such as a coaxial or optical input, you can use either of those for the PS3. Another option is to use one of the composite audio inputs, but however, your surround mode for that type of input will not be Dolby Digital, DTS or any of the high definition surround sound formats. You will instead be able to get one of the Dolby ProLogic formats, or one of the various surround modes that are proprietary to the receiver model by it's digital signal processor...depending on which you choose.
May 11, 2010 | Yamaha RX-V800 Receiver
Why cant I supply my onkyo surround sound system
You need to assign the HDMI input(s) to the functions they represent, using the Front Panel Tuning/Preset control...
If you connect a video component to an HDMI input, you must assign that HDMI Input to an input selector in Setup.
For example, you could assign the “DVD” setting to “IN1”, and assign the
“CBL/SAT” setting to “IN2”.
Likewise if you use digital audio inputs...
Assigning the Digital Input
If there’s no sound, press the [DIGITAL INPUT] button repeatedly until sound is heard. The digital input is now properly assigned.
If you connect your DVD player to the AV receiver’s COAXIAL 1 DIGITAL IN, and your cable/satellite receiver
to the COAXIAL 2 DIGITAL IN, as shown, it’s not necessary
to assign the digital input.
Feb 12, 2010 | Onkyo HT-S5100 Theater System
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Audio decoding
You will need to tell the PS3 to use the optical cable for digital output in its setup, as well as tell your amp to use the optical cable as the input for whichever 'source' you wish to have associated with the PS3.
Nov 22, 2008 | Sony Playstation 3 (PS3) Console
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Source always PCM, can't get Dolby-D
PCM is standard when using HDMI cables, you are passing an already decoded audio signal to the receiver and it outputs the sound and does nothing more. The reciever calls this PCM, your PS3, when pressing select should show that it is decoding the dolby digital HD. There is no quality difference in the two. PCM is the same because it is un compressed audio. So when using HDMI, no matter the signal that the movie or music is playing, wether it be dolby or DTS, you will see PCM when using HDMI.
Nov 24, 2007 | Onkyo TX-SR605 Receiver
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Marantz SR5007 Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
