Looks like a virus has disabled my cd rom how do i restore it
    Scholar:
  • 170 Answers
You should run your computer in safe mode and do a virus scan.
  1. restart your computer and press F8
  2. select safe mode with networking
  3. update your antivirus program
  4. do a full virus scan
Than if you CD rom still is not working these are the steps to enable it again.
  1. Right click 'my computer'
  2. click 'manage'
  3. on the left side click 'device manager'
  4. than on the right side locate your cd rom and click the + sign
  5. right click on the cd rom
  6. select 'enable'
Let me know if this helps, and please rate my answer. Good luck.
Posted on Jan 12, 2009
Acer Aspire 7741Z missing CD ROM drivers. Motherboard issue, maybe?
Usually, if the motherboard (meaning BIOS here) goes bad, you will lose all access to all drives. Since the CD-ROM and Recovery partitions have been targeted here, I would say you should be looking hard for a nasty virus or bot. They often attack by blinding your antivirus software, then they disable the CD-ROM (where you would reload from) and the recovery partition (same thing). This keeps them alive longer while you try to figure out what's wrong. I'm not saying that it COULDN'T be hardware or OS related, but first I'd run Malwarebytes or a third party A/V program to be sure that nothing else is wrong first.
Dec 10, 2013 | Acer Aspire 7741Z-4643
Cd rom drive door keeps opening up when in, it won't start cd
Try to this. Start - Right Click My Computer - Properties - Hardware - Device
Manager - CDROM - Properties - Disable. See if it Stops then enable it again.
Look at cdrom button it might obstructed or pressed in, try pulling and pressing. Or it could be a program/driver problem. Try restoring your pc the day before it happen.
Sep 14, 2011 | E-Machines emachines (emachinees) CD-ROM...
Hello the fan of the northbridge of my MS 7125 does not rotate, and when i boot up it lock down on Loading screen
HI. This issue with the NB fan will be a direct result of fan failure. The actual fan motor assembly may be shorted or disabled. This fan should be replaced asap(make sure to check the fan connector for proper connection before replacing the NB fan). Now, concerning your halted boot screen; This will be a direct result of a failed or corrupted OS(Operating System). I would recommend to initiate a system restore by inserting the restoration CD/DVDROM that came with the CPU system, when purchased or delivered. This will totally reinstall the OS and correct all corrupted files that have been affected by this unfortunate virus/worm attack.
Due to the fact that your system will not boot up, you will need to insert the restoration CD/DVDROM into its respective ROM device and shutdown the unit for five minutes. Once the shutdown has occurred, simply, restart your unit and follow the restoration instructions on screen during the hard boot. It may be necessary to self initiate the restoration by booting from the actual ROM device, via f11 or f9 command upon boot screen.
Sep 04, 2011 | MSI K8N Neo4-F Motherboard
My PC is very slow and keeps coming up with Errors, How do I clean my computer?
1. Buy an external disk-drive.
2. Copy all your music & files & E-mail & contacts to that device.
3. Find your original manufacturer-supplied "System Restore" set of CD-ROMs.
4. Find your original CD-ROMs for purchased software (Photoshop? Adobe? Microsoft Office? Nero? Anti-Virus?)
5. Find the original "product-keys" so that you can re-install that commercial software.
6. Re-install Windows, using those "System Restore" disks.
7. Re-install your purchased software.
8. Install anti-virus software.
9. Access: http://WindowsUpdate.Microsoft.com
to get all the security-updates for Windows.
Repeat until you have no more updates to be applied.
10. Reload your data from the external device.
Oct 23, 2010 | Computers & Internet
L have the cd but it will not download on my comptuer
If you have any other camera software, make sure you un-install it.
Place the disk in the Cd-rom. Open "my computer" and double click on the cd-rom drive that contains the disk. Double click on setup.exe.
This software takes approximately 15 minutes to install. Once installed, reboot the computer.
If you are still having problems; disable firewall and anti-virus before you install. After installation, enable the firewall and anti-virus and answer yes to any incoming/outgoing signals that your firewall tries to block.
Sep 17, 2010 | Microsoft LifeCam VX-3000 Web Camera
My cd-rom (tsstcorp cd/rom ts-h192c) cannot be read due to virus..what should i need to do?
i have never seen such a problem means virus causing harm to a hardware only in "DIE HARD 4".if you mean to say that autoplay is disabled the yamicsoft winxp manger can fixed it.have a nice day
Nov 24, 2009 | Belkin USB 1.1, 2.0 - Automatic The 4x1...
Cd dvd rom not working it says driver missing or corupted so i uninstalled it to allow vista to reload but still no luck keeping getting same message
I had a similar problem after a virus attack on yahoo messenger ..it affected my cd-rom driver ...and pretty much all the rest ..but first it ...I tried to reinstall but no luck ...so ...until I reinstalled the pc with a clean install I mean from the disk and formatting the C partition ...I didnt get anything ..but it worked after ...so ..this is what I suggest too ..
but first I suspect it to be disabled too ...so ..restoring factory defaults in the Bios will be a good thing too...
also you might try to look for it in the hardware manager ...and try to install it ..by downloading its driver ...and than run the wizard for installing from there ...just click update driver ...if it will be in yellow with an ask sign it means that has no driver ..
but ..reinstalling clean its still the right way ...Keep in mind that installing from a recovery stored in another partition ..might not do the job ..cause either it sees it disabled...or ..the virus that cause it ..do not dissapear ..and restores the damages..
Nov 06, 2009 | Acer Aspire™ T180 PC Desktop
I want to download a cd rom for toshiba xp psa72u-01300u
maybe you will first try to do system restore ??
startmenu-programs-accessories-system tools-restore system. And you will try to back before you got virus.
Jan 31, 2009 | Toshiba Satellite M35X-S109 Notebook
Acer aspire 3515 reboot
the error you are getting, is related to the computer not being able to find a logical Drive. ( Hard-Drive Or CD Rom ) this could be caused by either A Virus. Or a corruption in the operating System. ( Windows System File Et,c )
If you check your computers manual, or website or you can enter the computers Bios screen.
Look for an option to restore setup defaults or similar, and save and exit to cmos/Exit.
Also see if there are options for using system restore. ( this is where your hard-drive will contain a seperate partition ) to enable a set of backup files to be loaded and run.
If you have a wireless network connected, remove or disable, until computer has re-booted. As your system could have been taken over by a hacker or similar program/virus.
Thankyou for using Fixya.
Mike @ compurepair.
Dec 01, 2008 | Acer Aspire 5315 Notebook
Dvd/cd rom drives
i cnt run my dvd rom drive but only cd.disk
Oct 15, 2007 | ASUS 52x (CD-S520) QUIE TRACK BEIGE RETAIL...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
