Sony 46 streaks when turned on clears in 5 min
Tap on back also clears problem
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If a tap clears it you have a physical problem somewhere--loose plug or less likely but possible a very bad solder connection somewhere--cracked solder connections when they get warm suddenly expand just enough to make the connection.
Posted on Dec 08, 2012
3 Suggested Answers
gbean009
  • 5 Answers
SOURCE: I have a sony Bravia 46
its called burn in and yes it can go away over time. Be sure to not leave a static image on the screen (like a paused video) and leave it for an extended period of time.
playing video with high brightness and fast moving action can further help the problem go away.
Posted on Oct 23, 2009
walesarumi
  • 6993 Answers
SOURCE: nec accuSync 46 when turned on, last about 5 mins,
This issue is related to a power problem as long as the TV turns on and off by itself.
The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Walesarumi
Posted on Sep 28, 2011
What is the cause bravia 3 blinks?
Power supply has a voltage spike caused by damaged capacitors.
Jul 19, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
46 in Sony tv. about 4 yrs old. when you first turn it on it had ghost figures on theleft side of the screen.
If you are handy you can replace both the right and left side planer boards but it is a semi complicated job. The boards bought off market will only cost around 125 for the pair or less.
Good Luck Ed Pinero
Feb 04, 2013 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
Jan 15, 2010 | Sony KDL 46V5100 46 in. LCD HDTV
I deleted codes (banks 1 & 2 too lean, and cylinder 1 misfiring) and need to drive vehicle to turn sensors back on so I can smog the truck. How do I turn sensors back in? 2001 Ford F-150, 5.4 liter...
If you cleared the codes with a code scanner, or battery disconnect, all is should take to trigger the problem again is 2 driver cycles.
Drive cycle :
Operating temp engine ( let it warm up )
At least 1/2 tank fuel
A run of normal throttle usage, to maintain at least 46 mph for 5 min, back down to a stop and then back over 46 mph again ( 5 min ).
2 cycles of this should have the DTC P1000 code removed ( tests completed ) and if the error is still there, the CEL should illuminate again.
Oct 23, 2009 | 2001 Ford F150 Styleside SuperCrew
Black streaks appear verticaly on my screen.
hi this might be happening because of your cable if that isnt the problem then you will have to contact sony and let them know what is happening with tv
Jan 10, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
Sep 28, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
