Question about Garden
Starter wiring diagram for bobcat 843
Need to know wire location and colors on starter
  • 393 Answers
SOURCE: Installation (wire diagram) for remote starter on a 2001 Pontiac Sunfire
try going to diy rattler.com
Posted on Nov 15, 2008
JShreader
  • 50 Answers
SOURCE: NEED WIRING DIAGRAM FOR 2002 PT CRUSIER STARTER
Hello chk614, my name is JShreader. Thank you for choosing fixya.com.
Here is a picture showing the Wires connecting to the Starter...
If you are looking for the formal Wiring Diagram...see below...
I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader!
Posted on Apr 01, 2009
dmsr63
  • 2050 Answers
SOURCE: Wiring Diagram 1998 Chevy S-10 starter replacement
The starter has one large cable from the battery positive, and a wire that goes to the solenoid (Part of the starter) that becomes hot when the key ignition is turned to start. This also passes through the neutral safety switch. (So it wont start in gear) Not sure if this is what you need, a little vague.
Posted on Jul 06, 2009
  • 4 Answers
SOURCE: Black and Decker Electric Lawn Mower MM850 wiring diagram
I have repaired mines. It was found in the trash dump, just before street curb side trash collection. It is a very sophisticated lawn mower. It taken me a month to restore it. The problem is the housing is poor design and does not hold the pin switch securely. This is not a simple on/off switch. It is switch module with two momentary switches built in to it to work simultaneously. The hot is a normally open momentary switch and the neutral is a normally closed momentary switch. Two things must occurred simultaneously for the lawn mower to work. The AC hot has to close and the neutral to open. This is a split phase AC motor. The switch has four connectors to it. The first two has black wires to it, for the hot, that is normally open. The second two has a white wire and red wire to it for the motor's start up winding. The orange connects with the plug's white, neutral. A new substitute switch will be two individual momentary switch, one for the two black wires will be normally open and the two for the red and white wires from the motor start coil will be normally close. It will take two fingers to operate the lawn mower. I recommend you to buy a new and each switch from Black and Decker.
The problem with the system is not the switch, but the poorly designed switch box housing. Often, there is nothing wrong with the switch. I tested mines and it works fine. The problem is the switch box housing does not keep the switch in the correct position for the higher tension spring lever to press against it to operate. I use small washers to stack between the rear of the switch inside and reassembled the switch box upside down by turning the handle upside down, so the washers and switch do not fall out. Once I am finished assembling the switch box and position it on the handle, then I position the handle back to the normal top side and attach the handle back to the lawn mower. I am finished.
http://en.wikipedia.org/wiki/AC_motor#Split-phase_induction_motor
"Split Phase Motors
Split phase ac motors are widely used for low power applications as for example in oil burners, furnace blowers, garage door openers and major appliances. Such motors employ separate run and start windings connected in parallel across the acpower source. When the motor is initially energized both windings are energized, and when the rotor speed reaches about eighty-five percent of the normal running speed the start winding is disconnected from the circuit. Various devices are utilized forthis latter purpose and include centrifugal switches and current and voltage relays.
A problem which is characteristic of these motors is that they have a relatively short operating life. The principal reason for this is the failure of the switching devices used to cut out the start windings when the rotors approach the normalrunning speeds.Failure of these switching devices in turn cause the start windings to burn out.
One of the reasons for the failure of these switching devices is the high currents which they are carrying at the time the contacts open. Attempts to increase contact life by use of improved designs and materials have not been altogethersuccessful. Another disadvantage associated with these switching devices is that they are necessarily quite large and occupy a substantial space in the motor housing." -from another web site.
Posted on Sep 08, 2009
  • 484 Answers
SOURCE: need wiring diagram for 2000 dodge neon
i would recommend buying a Haynes manual, as they have very good diagrams and schematics. If you do not want to buy one, though, you can create an online garage on Autozone.com by registering (which is free) and add your car to the garage to get access to a free manual online. These manuals are kind of hit-or-miss, though, and i have had mixed results with them. But for free, it is worth looking into first.
i hope this helps,
matthew
Posted on Oct 25, 2009
What are the ignition switch connections on a bobcat 720? The manual gives me the wire colors, but the connections are too blurry to accurately tell what wire goes to which terminal. It is a 4 termina
it requires 3 wires to start 2 to feed power to ignition and 1 to acativate starter , signal wire ,if you use a test light and find power and make up 2 sets of jumper wires once you touch the red wire to any 1 wire you should hear starter ingauge but it wont stay running till you connect yellow and black wire , once you know what wires do what its easy. that's the way I remember it im sorry if this is confusing if I was there it would take 5 min.
Oct 25, 2014 | Cars & Trucks
Bobcat starter stays engaged
Trace the wire from the "st" on the ignition switch to the small post on the starter relay or solinoid. If you find another wire going off from there follow it to the diode. It is likely covered with insulating sleeve at one end of the wiring harness. It is about 3/8" in dia and 3/8 long.Please note the colored band at the end which denotes the cathode.It must be replaced with one going the same way..
Hope this helps, Robert
Aug 16, 2012 | Bobcat Welding Tools
Need to know how to hot wire ignition.what color wires do i use?
1991 Ford F150
Vehicle Battery Positive Wire (+): Yellow
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Red/Light Green
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): N/A
Vehicle Second Ignition Wire Location: N/A
Vehicle Accessory Wire (+): Gray/Yellow
Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): N/A
Vehicle Second Accessory Wire Location: N/A
Automobile Engine Starter Wire (+): Red/Light Blue
Automobile Engine Starter Wire Location: Ignition Switch Harness
Automobile Second Engine Starter Wire (-): N/A
Automobile Second Engine Starter Wire Location: N/A
Factory Anti-Theft System: None
Factory Anti-Theft System Type: None
Car Key Sense Wire (-): Black/Pink
Car Key Sense Wire Location: At Steering Column Harness
Car Neutral Safety Wire (+): N/A
Car Neutral Safety Wire Location: N/A
Car Tachometer Wire (-): Tan/Yellow
Car Tachometer Wire Location: At Ignition Switch Control Module in Driver Fender Well
Car Speed Sense Wire: Gray/Black
Car Speed Sense Wire Location: Pin #3 at PCM Mounted on the Firewall
Car Parking Lights Wire (+): Brown
Car Parking Lights Wire Location: At Headlight Switch or Driver Side Kick Panel
Car Brake Lights Wire (+): Green
Car Brake Lights Wire Location: At Brake Switch Above the Pedal
Car Reverse Lights Wire (+): Black/Pink
Car Reverse Lights Wire Location: At Switch on Transmission
Car Horn Wire (-): Blue
Car Horn Wire Location: At Steering Column Harness
Sorry friend, this is as far as i can go to tel you how to hot wire the ignition. But with the color codes you should be able to figure it out, Good luck and keep me posted.
Jan 23, 2010 | 1991 Ford F150
TRYING TO INSTALL REMOTE STARTER, INSTRUCTIONS
go to bulldogsecurity.com they have wiring color codes and locations for your vehicle.Also they list any special relays that you may need for factory security.
Please be sure to rate if this helps you out
Dec 29, 2009 | Astra Car Alarm And Remote Starter,...
Hooking up a remote start and need to know ignition starter wire location and color and also accessory blower wire color and location
highly recommend installing a factory remote starter system if not install properly will have all kind of problems, go to any chrysler jeep dodge dealer and buy a factory system, they do have simple instructions
Nov 17, 2009 | 2007 Jeep Compass Limited
NEED TO REPLACE THE GROUND WIRE TO THE STARTER ON A 99 FORD F250 LIGHT DUTY WITH 5.4 V8 AND NEED A WIRE DIAGRAM
why do you need a diagram?, if you have a new one, just route and install it just like the old one.
Oct 14, 2009 | 1996 Ford F250 Crew Cab
Bobcat 642 starter is not engaging
The" extra"12vdc solenoid mounted on the left side of the engine is for more AMPS to go to the smaller solenoid on the starter motor. This solenoid is a 3 wire I think. 1 big cable on one side goes to the positive lug on the starter small solenoid HOT BATTERY connection is and system power, the other side cable on the frame mounted solenoid goes to the TRIGGER lug on the small solenoid on the starter motor. The center wire goes to the " S " terminal on the key start switch. Sounds like you have either\ and some bad cables ( getting hot ) and possiably a bad ground from the battery NEG post to the ENGINE BLOCK. With no ground it does not matter how much voltage you have, it wont work. May also have a failing solenoid on the frame. If you remove the cable going from it to the starter solenoid, for testing, and try to start the engine, you should here a " clunk " from it where it is engageing internaly and have battery voltage where you took off the wire. Good luck
Mar 21, 2009 | Bruder Cat Skid Steer Loader
How to install a remote car starter
The remote start should come with instructions, you will need these especially for the diagram of the units wiring harness.  It will need to be wired into the ignition key on wire, the ignition starter wire, power and ground, and usually the brake light wire, and a hoodpin disable switch that will come with the unit.  Also most manufactures will have a website with vehicle specific details like color and location of each wire on the vehicle.  hope this helps.
Oct 30, 2008 | 1998 Ford Contour
Garden Logo
810 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
