Question about Broaster Pressure Fryer
I need wiring diagram to broaster 1400E chenge a 220 voltios
    New Friend:
    Problem Solver:
  • 5 Answers
GVE_10
That is a tough one, as 1400E has been out of production for 30 years. Parts have been discontinued for about 20 years. When you say you need to change voltage, that machine was made as 208 0r 240. 240 machine was always fine on 220 volts. 208 machine could burn out heating element over some time, but since you cannot buy other elements anyway, I would just go ahead and use the machine. If your real question is how to convert from 1-phase to 3-phase or vice versa, that is different story, and I can help you with that.
Jon
jondf1@gmail.com
Posted on Mar 24, 2013
Wiring diagram for sx model
look on the side of the motor it has a diagram for both 240 and 120 if wiring 220 motor should already be wired if 120 volt you have to move the wires shown on diagram
Aug 27, 2014 | Pool & Spa
I need to wire a SP2607x10
look on motor should be a diagram pump is wired from factory for 240 volts if wiring 120 volts you have to chenge the brown and white wire see diagram then black goes to F1 white goes to F2 where white wire is
Jul 08, 2014 | Hayward SUPERPUMP 2.0 HP, 115/230V
I have a broaster that turns on but will barely heat the oil. Does anyone know what would be causing this?
Is it made by the Broaster Company or a spin off like a Henny Penny? Is it gas or electric? If by the Broaster Company would it be a 1800 or a 1600? Give me this information and than I can tell you what the problem is. Not an expensive fix either.
May 09, 2014 | Broaster Pressure Fryer
Have a oil leaking problem in broaster chicken fryer
Faisal,
I am a Broaster distributor, and have parts available. Which model do you have, and you are saying the bottom drain valve is leaking, correct?
Jon
jondf1@gmail.com
Mar 14, 2013 | Broaster Pressure Fryer
Wiring diagram for aosmith a48a93a66 motor
Label will show wiring diagram.
Usually: L1 Line 1 will be 120V Hot
L2 Line 2 is Neutral
Low voltage is 115 volts
High voltage is 220 volts
Motor shipped new with 220V default
Compare existing wiring to what appears on label.
Label will show wire colors Brown, yellow, red, white etc.
Move these wires as needed to change voltage.
Take photo of label, post on internet, add comment with link to photo so diagram can be viewed.
Nov 08, 2012 | Pool & Spa
Where can I find a instruction or service manual for a Broaster 1400 E ? jprettie@excel.net Thank yoiu
Hi there.
Try visiting this web for manuals.
http://www.broaster.com/fdsvceqp.htm
Regards.
Jul 05, 2011 | Kitchen Appliances - Others
Looking for wireing schematic for a 1400E broaster and does it take 120 volts to activate the contacts
I'm looking for an owners manual for a Broaster 1400 E.
Could you tell me where I can find one?
Thank you
Nov 20, 2009 | Kitchen Appliances - Others
I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Nov 03, 2009 | Kitchen Appliances - Others
I need a wiring diagram for a kobalt 60 gallon air compressor
If it's a 220 volt motor, hook l1 and l2 (220 volts) to the line terminals. If it's a'dual voltage' motor (120 or 220)and you want to use 120, hook 120 to the terminals marked 'line'. Make sure the motor is connected for the voltage you're using if it's dual voltage.
Jul 21, 2009 | Air Tools & Compressors
Need to wire for 220 power
Often, the 220 wiring diagram is on the back side of the plate that's screwed on the motor junction box. Or it is on the spec plate on the motor.
May 16, 2009 | Delta Machinery Delta 37-275X X SERIES 6"...
Broaster Pressure Fryer Logo
152 people viewed this question
Top Broaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Broaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
